FS: JDM ITR / JDM Lug Nuts / AEM 3" / PR3 pistons on P72 rods / GSR Crank / OEM / P54 AC Bracket /
Hello, I have some stuff for sale. Located in the The Bay Area, CA. Prices are or best offer and without shipping.
PM is the key
1. JDM ITR drivers side (usdm passenger) non-HID Headlight - lightly hazed lens, small crack by the tab $old
2. JDM ITR Front Bumper, Painted Milano Red, uncut grill, the paint on certain parts are not in the best cosmetic condition, but still very usable. No physical deformation. Broken lip tabs. Most of the bumper is
$old
3. Lightweight Red (pink) JDM lug nuts. Sold to me as Work lug nuts back in 2003. These bad boys served me well for 3.5 years. The nuts faded to jdm pink, the locks are still blood red. Story about the locks, I lost the key for them one day, and I needed them off, so I hammered a socket on it and took off some of the metal. But then I found the key right after I did that. The locks have been used since then, so they are perfectly functional. Set of 16 for 4 luggers. $40
4. Lightweight Black JDM lug nuts. Sold to me as Spoon lug nuts, although they look the same as the Red ones I have lol. These have normal wear on them from taking off/on wheels. Set of 20 for 5 luggers. $old
5. AEM 3" ITR Shortram Intake /w filter: Used to be a Cold air, but I cut it 3 years ago. Also painted black. I put a AEM GSR CARB sticker on there, and it has worked every time against the police. Comes with filter, silicone hose, hose, and hose clamps $75
6. PR3 Pistons on P72 Rods (2000 B16A2 pistons, 2000 GSR rods) : Raises a GSR's compression from 10:1 to 11:4 (according to c-speed compression calculator) $100
7. Apex N1 Silencer, 110mm $20
8. 2000 GSR Crank: Spun a bearing on it, but I caught it early. Light scoring on the journals i've marked: Best Offer
9. 88-89 CRX tail lights: comes with used gaskets and harness $50
10. B-series Passenger side Axle $50
11. ITR / GSR lower timing belt cover $30
12. AC Compressor from a gsr swap, never used it $20
13. B-series Starter out of a 00 Si $50
14. B-series Alternator out of a 00 Si $50
15. Del Sol P54 AC Bracket You need this to use your AC in your swapped 92-00 civic (Use stock compressor) $old
16. GSR Throttle Body, comes with both MAP and TPS sensors $45
17. New D16Y8 Timing Belt Kit from prostreetonline: Includes new timing belt, water pump and tensioner $old
18. Built GSR Head: Roughly 15k miles. Comes with vtec solenoid.
Port & Polish head
Milled .30
Skunk2 valve springs
Skunk2 titanium retainers
Ferrea valves
No Distributer, No Intake/Exhaust Manifold, No Cams
$900
PM is the key
Modified by milano2kdc2 at 10:46 AM 7/22/2007
Modified by milano2kdc2 at 7:47 AM 7/26/2007
Modified by milano2kdc2 at 10:01 PM 7/27/2007
Modified by milano2kdc2 at 4:19 AM 8/2/2007
Modified by milano2kdc2 at 8:30 AM 8/11/2007
PM is the key
$old3. Lightweight Red (pink) JDM lug nuts. Sold to me as Work lug nuts back in 2003. These bad boys served me well for 3.5 years. The nuts faded to jdm pink, the locks are still blood red. Story about the locks, I lost the key for them one day, and I needed them off, so I hammered a socket on it and took off some of the metal. But then I found the key right after I did that. The locks have been used since then, so they are perfectly functional. Set of 16 for 4 luggers. $40
Port & Polish head
Milled .30
Ferrea valves
$900
PM is the key
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBoostedDA »</TD></TR><TR><TD CLASS="quote">i'll take the headlight. PM you</TD></TR></TABLE>
replied
replied
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R »</TD></TR><TR><TD CLASS="quote">How many miles does that alternator have on it? How about $40?</TD></TR></TABLE>
pm
pm
