DC JDM header help
depends on which carsound you buy. i think you should talk to SMSP for your cat needs. cos i know if you are going to mate the carsound to your OEM bpipe yoiu need to get a 2.5" fange welded on.
i got the carsound cat w/ my jdm DC header. I the carsound came w/ a gasket which i used to match up w/ my stock ITR exhaust..and it started leaking..i went back and got a bigger gasket and it stopped the leak. if that helps
nothing huh...
ok, Your option is definitely cheaper.
Anyone else?
Anyone else?
[e]don't forget donut gasket and bpipe gasket
[Modified by sackdz, 9:45 AM 6/10/2002]
A little help¿
So here are my three choices:
JDM 4-1 Stainless Steel Header (no gasket, no collector flange) Price: $377.99
JDM 4-1 Stainless Steel Header w/ gasket (no collector flange) Price: $407.99
JDM 4-1 Stainless Steel Header w/ gasket & collector flange Price: $462.99
...and a Carsound Cat from IPS racing.
The header, donut gasket, and Carsound cat. from IPS or SMSP are all that you'll need for the install. There will, however, be a large mismatch in ID between the outlet of the cat. and the inlet of the B-pipe.
It fits, but clearly the inlet is a severe bottleneck. Dave has two solutions - an adapter for the stock B-pipe that tapers from 2.5" to 2.25" or a full 2.5" cat-back system. The adapter would obviously be the more budget-minded approach.
This is the adapter for 60mm cat back systems in stainless.
i have jdm dc 4-1 and smsp carsound cat. and just order this exact same b-pipe adapter from smsp. I'm hoping to see some butt dyno difference after this mod...
Just use duct tape, it works for everything.
Hmm, just make a new b-pipe out of the tape and Jack in the Box straws...those things are HUGE!.
Kenton
Kenton
Kenton
Arby's now carries enlarged straws as well.
Kenton
Kenton
Yesman
23
Jul 25, 2002 04:59 PM
...and I gues superfat exhaust fixes all that.
