Tire Size...
Old Jul 18, 2007 | 07:29 PM
JDM_Acccord's Avatar
Default Tire Size...
Right now on my 17X7 Rays, i have Falken Ziex tires that are 205/45/17 and appears that they are stretched a little and i could go with a bigger tire. can i put a 225/45/17 tire on the rims? thanks.
Old Jul 18, 2007 | 07:32 PM
Doostur's Avatar
I'm guessing your car is an accord? You dont rub at all now? Car lowered?
Old Jul 18, 2007 | 08:01 PM
Default Re: (Doostur)
nopee.. rolled the lip
Old Jul 18, 2007 | 08:56 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire Size... (JDM_Acccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">Right now on my 17X7 Rays, i have Falken Ziex tires that are 205/45/17 and appears that they are stretched a little and i could go with a bigger tire. can i put a 225/45/17 tire on the rims? thanks.</TD></TR></TABLE>
You might be able to mount the tire on the rims, but that doesn't mean it's the best size for your car.
Most 225/45-17 tires are approved for mounting on rims 7.0-8.5 inches wide. At the low end of that range, they will appear to be bulging.
What kind of Accord do you have - year? coupe/sedan/wagon? EX/LX/etc? 4 cyl or V6?
Oh, and the Ziex is not very good. If you really need all-seasons, try the Kumho ASX; for about the same money, it's much better in every way.
Old Jul 19, 2007 | 01:33 PM
Default Re: Tire Size... (nsxtasy)
it's a 1996 accord 4dr lx 4cyl.. i was going to put 225/45/17 falken azenis tires.
Old Jul 19, 2007 | 04:55 PM
Loco-B's Avatar
whats the width and the offset of the rays?
Old Jul 19, 2007 | 08:57 PM
Default Re: Tire Size... (HateBreeder)
im not sure of the offset... it's 7in. wide.
Old Jul 19, 2007 | 09:43 PM
Loco-B's Avatar
i bet that they have an offset over +40mm.
anyways. on a 7 inch wide tire i would highly suggest 215's. 225 might look a little too meaty. and like you already stated 205 looks like its stretched
Old Jul 22, 2007 | 08:10 PM
well then does this tire look too meaty? because i think it looks fine.. this is on my friend's car, it's a 225.. the rim is 7 inches wide.. same as my rays.
Old Jul 24, 2007 | 07:40 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">it's a 1996 accord 4dr lx 4cyl.. i was going to put 225/45/17 falken azenis tires. </TD></TR></TABLE>
That's too big for your car and will probably rub. Get 205/45-17. If you have to get the Azenis, 205/45-17 isn't available; you can try 215/45-17, which might rub slightly, but not as bad as the 225/45-17.
Old Jul 26, 2007 | 08:33 PM
it's not about how it looks or how it will rub.. it's about the performance, how it will stick to the road.
Old Jul 26, 2007 | 09:10 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">it's not about how it looks or how it will rub.. it's about the performance, how it will stick to the road. </TD></TR></TABLE>
If you're really looking for performance, get the Bridgestone RE-01R in 205/45-17. It will give you car the best performance, best "stick to the road". And it won't make your car accelerate slower like those oversized sizes will.
Old Jul 26, 2007 | 09:18 PM
im probably going to get 225.. 205's are stretched.. super stretched.
Old Jul 26, 2007 | 09:30 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">im probably going to get 225.. 205's are stretched.. super stretched.</TD></TR></TABLE>
Not true. Not true at all. Most 205/45-17 tires are approved for mounting on rims 6.5-7.5 inches wide. That means they will look stretched on a 17x7.5, and will look bulging on a 17x6.5. But on a 17x7, they will look absolutely perfect.
With 225/45-17, OTOH, they are usually approved for rims 7.0-8.5 inches wide. Which means that on a 17x7, they will look really funny, like they are bulging outwards.
But it sounds like you already have your mind made up, even though it appears that you don't know what you are talking about and don't know much about tires. If you want to get the wrong size tires that won't give you the best performance, be my guest. I just don't understand why you even bothered asking if you're just going to ignore the knowledgeable advice you get in response.
Old Jul 26, 2007 | 10:09 PM
Doostur's Avatar
Haha... classic
cooldudeness
Jun 16, 2007 04:00 PM
sony224422
Mar 19, 2007 06:01 AM
dt4life
May 4, 2006 01:38 PM
FalconMan
Nov 25, 2003 02:24 PM
RedLinin247
Jun 24, 2003 04:09 PM
