timing belt doesnt fit after just changing the headgasket.......wtf
Old Jul 18, 2007 | 07:19 PM
SomeDude56's Avatar
Default timing belt doesnt fit after just changing the headgasket.......wtf.... Edit worked that hoe, got it
So I went and changed the headgasket and upgraded to arp headstuds. Get everything back together mind you im using the same water pump, cams, tensioner, Everything and now the t-belt wont fit....wth. The tensioner is not tight and I tried with the spring on/off and its to short.........what the hell could cause this. Any insight or help would be greatly appreciated. thanks
Joey
Modified by SomeDude56 at 11:13 PM 7/18/2007
Old Jul 18, 2007 | 09:02 PM
garageEF's Avatar
Default Re: timing belt doesnt fit after just changing the headgasket.......wtf (SomeDude56)
take off the tensioner spring and lube up the belt....its a bitch but it will fit.
Old Jul 18, 2007 | 09:06 PM
SomeDude56's Avatar
Default Re: timing belt doesnt fit after just changing the headgasket.......wtf (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">take off the tensioner spring and lube up the belt....its a bitch but it will fit.</TD></TR></TABLE>
I tried it with the spring off, the only way I got it on was with taking the tensioner all the way off and then holding the t belt over as hard as I could and threading the tensioner in but is it supposed to be that damn tight? it sure as *** didnt feel like that comin off.
Old Jul 18, 2007 | 10:13 PM
SomeDude56's Avatar
well after the 2am *** with it session I have gotten it on but I couldve sworn it was a helluva lot easier getting off. One of the downsides to drinking and wrenching I guess . I had to get it on there by looping it around the cams, lower crank pulledy, water pump, and then working it onto the tensioner. But i still have a few questions.
1. on c speedracing they take the lower crank pulley and match it up with the notch on the block and then when the belts on turn it counter clockwise three teeth........but this is the only time ive seen this mentioned (im not doubting them they obviously know there ****) but is this totally necessary?
2. The notchs on the came gears are lined up but the "up" markings on the cam gears dont excatly match very well......im guessing they just put that there to let you know what side needs to be up then ugh?
some dumb questions I know but I always question some stupid **** when doing stuff like this.
thanks
Joey
walrus0
Honda Civic (2001 - 2005)
Sep 13, 2012 09:56 PM
OH_1fstgsr
Mar 7, 2007 10:13 AM
ganjafarmer143
Oct 17, 2005 03:57 PM
ElectronSi
Dec 29, 2004 07:06 PM
92B20GSR
Nov 17, 2003 02:04 AM
