NO COMPRESSION
hello my engine has no compression i would like to know if someone could please tell me the steps of how its done and what i am going to need to do it...........i am planing to do it my self can somone tell me if it is worth doing it? it is a honda accord lx 1994
engine : F22B2
Compression Ratio :8.8 : 1
thank u for all ur help
Those numbers doesnt make much sense to me. When you do a compression check, you get the numbers for all 4 cylinders and post up the numbers.
I know you could calculate it and get the compression 8.8 : 1, but it is more important the difference between the numbers and not the actual number itself. The difference should not be more than 10% between cyclinders. This is because different compression guages will tell you a different number, but they will all tell you the difference between the cyclinders fairly accurately.
What is the mileage on your Accord?
builtprelude
Jan 22, 2004 10:49 PM
