Shaved head+ RS 85mm ITR's
Old Jul 18, 2007 | 03:03 PM
HighRevn's Avatar
Default Shaved head+ RS 85mm ITR's
Im planning on buying the Rs itr 85mm pistons for my b20/vtec build, and I was thinking of shaving my b16 head a bit to raise the compression a bit more....anybody done this with there setups. is there enough clearance to run say a blox b or a pro 2?
Old Jul 18, 2007 | 05:31 PM
HighRevn's Avatar
Default Re: Shaved head+ RS 85mm ITR's (HighRevn)
Somebody has had to of tried this.....
Old Jul 18, 2007 | 06:03 PM
kabaroo's Avatar
You would want to clay your motor or something to make sure piston to valve clearance is a go! Im doing the same thing with the RS pr3 pistons in a 82mm bore. Except Im running s2s2 cams.
monster_c
Nov 26, 2011 12:23 AM
97-crv-owner
Sep 18, 2008 07:42 PM
b20powereDA
Jun 21, 2007 04:40 PM
drunknbass
Aug 19, 2004 04:36 PM
B16Hatchcx
May 3, 2004 08:08 PM
