Torque Specs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtycolombian »</TD></TR><TR><TD CLASS="quote">Does anybody know the torque specs of the screws on the oil pan and also the screws for the header?
What engine?
Hondahookup has most of the factory manuals with torque specs in them if you just want to look them up yourself.
</TD></TR></TABLE>What engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">I think its like 9ft lbs on the oil pan bolts. either 8 or 9. Just make sure u don't overtighten or strip them suckers.
Uh, I think it is in inch pounds for the oil pan. If I remember correctly it was something like 25 inch pounds.
I always turn the oil pan bolts down till they bump up against the metal washer in the gasket and than give them a 1/4 turn.
</TD></TR></TABLE>Uh, I think it is in inch pounds for the oil pan. If I remember correctly it was something like 25 inch pounds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">The last time I looked in the manual, it was 8 or 9 ft lbs.</TD></TR></TABLE>
Hmm, maybe thats right. Just seems like alot for a 10mm
I think there is a certain pattern you should follow also when bolting them on. Try to look into that because I did it a few times in regular order and it slightly leaked. Then someone told me to do it at a different order and it worked.
NewtwoHondas
Jun 25, 2006 04:20 PM
