Changing the timing belt with the motor out of the car
How easy is it to change the timing belt with the motor out of the car and on a crate? Is there a trick to keeping the crankshaft from moving when taking off the crank pulley?
its suppperrrr easy to do it with the motor out of the car. i would really take the belt off from the cam gears first, then the crank pully. ive always done it that way. with the motor in or out of the car.
i always had a buddy hold the pully itself and had a long pipe or something of that sort on the ratchet im using, and used quick spirts of force to the bolt. like an impact wrench, only a manual one.
c1v1c98
Nov 15, 2008 08:42 AM
yosuthnmasa
Apr 8, 2008 07:29 AM
