jdm fog lights
Wiring is the same except that there's no 7-pin light switch plug for OEM JDM switch harness.
http://www.hondaautomotivepart....html
ok this is what im trying to figure out..the switch harness... obviously the connector for the switch is self, the 1-pin blue taped connetors that goes to the fog light harness then there is the 4-pin connector that goes to the relay..also comes with a ground wire that i would assume is grounded to the steering column then there is a 2 1-pin connectors one red and one white i have no clue what to do with those
1slowcrx
Nov 9, 2011 12:41 PM
jdmstockeg6
Feb 26, 2008 11:08 AM
