wat kind of cluth should i use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_Boy_626 »</TD></TR><TR><TD CLASS="quote">i have a A1 tranny on my EF wat kind of cluth should i use?
You can't possibly expect an answer unless you tell us what motor and what transmission.
</TD></TR></TABLE>You can't possibly expect an answer unless you tell us what motor and what transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote">I'm guessing its a d16a1 tranny from and 89 integra and a d15?
Not possible.
</TD></TR></TABLE>Not possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Not possible. </TD></TR></TABLE> hence the
but explain is it merely spline count you are referring to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote"> hence the
but explain is it merely spline count you are referring to? </TD></TR></TABLE>
Bolt patterns on the case and trans mounts are different.
but explain is it merely spline count you are referring to? </TD></TR></TABLE>Bolt patterns on the case and trans mounts are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF7 »</TD></TR><TR><TD CLASS="quote">He said A-1 so maybe a swap with a 86-89Integra trans? but, what is a CLUTH?</TD></TR></TABLE>
fixed
fixed
fixed</TD></TR></TABLE>A B series A-1 trans is from a 90 Integra my brotha!
If the A-1 he is referring to is the trans. We build these on a daily basis
The 86-89 Integra will have the CG-5 and CG-6 codings on the trans.
</TD></TR></TABLE>Gotcha I was thinking he was correlating the trans to the block...d16a1
