Questions about an OBD1 JDM H22A into a 98 Prelude SH
Old Jul 17, 2007 | 04:57 PM
litlsquirrel's Avatar
Default Questions about an OBD1 JDM H22A into a 98 Prelude SH
So recently my motor blew out on me in my 98 SH, this receipt says it all.
I purchased a new motor and I plan on swapping it in next week.
I wanted to save some money and not worry about my ATTS so I bought this.
It's 95 JDM H22A with tranny, lsd, and ECU. What I need to know is, what complications am I gong to run into, if any. I know this swap has been done before so I am hoping someone who has done the same one will see this. I would like to keep everything OBD1 if possible. I need to know everything that needs to be swapped from my blown motor to my new motor. Any help would be greatly appreciated.
Old Jul 18, 2007 | 07:58 AM
Default Re: Questions about an OBD1 JDM H22A into a 98 Prelude SH (litlsquirrel)
help, anybody?
Old Jul 18, 2007 | 08:00 AM
vinuneuro's Avatar
Should be straightforward.
Old Jul 18, 2007 | 08:36 AM
NirVTEC's Avatar
Default Re: Questions about an OBD1 JDM H22A into a 98 Prelude SH (vinuneuro)
I wouldn't call swapping an OBD1 non-sh setup into an obd2 sh chassis straightforward.....
Its been done......SEARCH is your friend!
Another H22A4 at less than 100k miles bites the dust........Starting to see a trend as time goes on!
Old Jul 18, 2007 | 08:57 AM
ludenoob99's Avatar
Default Re: Questions about an OBD1 JDM H22A into a 98 Prelude SH (:=:NirVTEC:=:)
well would it be easier to convet it to obdII? i kinda had the same question most of the motors i see for sale are obdI and i relize from a tuning standpoint thats better but does it make it that much more difficult to swap into an obdII car?
Old Jul 18, 2007 | 09:56 AM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :=:NirVTEC:=: &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't call swapping an OBD1 non-sh setup into an obd2 sh chassis straightforward.....
He's got an OBD1 ecu and OBD1 engine. What's so hard about it? At worst he needs an adapter for the harness.
Old Jul 18, 2007 | 10:08 AM
h22a1_julien's Avatar
yup...all you need is a onversion harness.....skunk 2 has them...its around 50$
Old Jul 18, 2007 | 10:56 AM
98vtec's Avatar
moderator emeritus
Default Re: Questions about an OBD1 JDM H22A into a 98 Prelude SH (h22a1_julien)
If you use the OBDI harness (which mmost times is impossible because it is hacked up in the engine removal process), then sure its not much work. But when you want to run the OBDII harness, there is alot more to it.
Old Jul 18, 2007 | 04:32 PM
Default Re: Questions about an OBD1 JDM H22A into a 98 Prelude SH (98vtec)
^^^, Here is my OBD1 ECU:
So the best way to do it without worrying about a wiring headache would be to plug everything right into my OBD2 ECU which is already intalled and then run a jumper harnes like this:
http://cgi.ebay.com/ebaymotors...ZWD1V
to my OBD1 ECU?
Old Jul 18, 2007 | 04:56 PM
98vtec's Avatar
moderator emeritus
what engine harness are you using?
If you use the OBDII harness, you have to swap the OBDI distributor, oil pump, lower timing cover...etc. You also need to be sure you use the a4 intermediate shaft as they are different between the A and A4.
Old Jul 18, 2007 | 05:20 PM
Yes, I plan on using my OBD2 harness. So I have to use my OBD2 distributor, oil pump, crank sprocket, intake manifold, and half shaft on my OBD1 motor? Is that everything then, what else needs to be swapped for this to work? If I want to go OBD1 then, I need the jumper harness to go from my OBD2 ECU to my OBD1 ECU correct?
Old Jul 18, 2007 | 05:25 PM
98vtec's Avatar
moderator emeritus
full list of things i swapped over from my A4 motor to the A motor:
distributor
oil pump
oil pan and baffle
intermediate shaft
lower timing cover
complete intake manifold
header
PS pump and mount
Alt and mount
AC comp and mount
thats it if i remember correctly.
also did the h23 timing conversion while the engine was out.
yes, if you run your OBDII harness, you just need the OBDIIa-OBDI conversion harness to hook it up to the OBDI ecu.
Old Jul 19, 2007 | 07:37 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">full list of things i swapped over from my A4 motor to the A motor:
distributor
oil pump
oil pan and baffle
intermediate shaft
lower timing cover
header
PS pump and mount
Alt and mount
AC comp and mount
yes, if you run your OBDII harness, you just need the OBDIIa-OBDI conversion harness to hook it up to the OBDI ecu.</TD></TR></TABLE>
Again......not straightforward.
Old Jul 26, 2007 | 07:30 PM
distributor
oil pump
oil pan and baffle
intermediate shaft
lower timing cover
header
PS pump and mount
Alt and mount
AC comp and mount
In order to actually use my OBD1 (p13) ECU will I need it tuned if I am using an OBD1 motor?
skarpenz
May 23, 2008 07:15 PM
trucdoken
Oct 11, 2007 11:01 PM
superturboprelude
Aug 10, 2005 06:32 PM
OzWolfbane
Mar 4, 2005 04:04 PM
