Bore Size
Old Jul 17, 2007 | 04:28 PM
Twistedframe's Avatar
Default Bore Size
I'm about to do a full engine rebuild on my F22 and am wondering about common bore sizes that people have done successfully in the past? What size can you go to on this engine before needing to sleeve it, or would you always need to add sleeves when doing this? I assume finding pistons won't be an issue as there are companies that cane make custom sizes, but I wonder if there is a few pre-set sizes that folks upgrade to to save the money and hassle of having custom pistons fabricated. I would like to bore it to 2.4 liters or more if possible.
Old Jul 17, 2007 | 06:41 PM
F22dreams's Avatar
Default Re: Bore Size (Twistedframe)
well word on the street if you go with a H22 selve its helps a hole lot more on F22 engine great set up drops the compression i believe its on the forum somewhere i seen it !!!
Old Jul 17, 2007 | 10:02 PM
JDM_DC4_Fanatic's Avatar
Default Re: Bore Size (F22dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F22dreams &raquo;</TD></TR><TR><TD CLASS="quote">well word on the street if you go with a H22 selve its helps a hole lot more on F22 engine great set up drops the compression i believe its on the forum somewhere i seen it !!!</TD></TR></TABLE>
This is not true. The H22 engine has fiber reinforced sleeves, where as the stock F22 came with Iron sleeves, much stronger and more durable.
As far as making the engine a stroker, there are stroker kits avaliable for the H22 from crower. They dont work for a normal F22 because the bore size is diffrent, but if your going to bore the motor out anyway, it may be a consideration.
For a complete list of engine specs and sizes, I suggest you read through this:
https://honda-tech.com/zerothread?id=1232811
Old Jul 18, 2007 | 12:18 PM
Default Re: Bore Size (Mr Wonderfull)
Awesome, thanks guys!
So, how much different are the A6 heads' intake and exhaust ports from the B2's ? Can you use the B2's intake and header on that head?
I purchased the Gude Performance Head Package a few years ago, which is the B2 head that has been ported and polished, had a valve grind done and was milled for high compression chambers and the addition of a Bullfrog Race Cam.
Shouldn't the work performed by them have addressed that flow issue of the B2 head? -Or should I sell the entire package and go with the A6 ?
Also, that interesting that you say to de-stroke it, because I was wondering about this very thing last night. Wouldn't it allow it to turn higher rpms if you went down in stroke length with larger diameter pistons? Should make for some nice power increase?
22accordts
Sep 10, 2010 09:22 PM
YingYangh22a1
Nov 14, 2007 01:33 PM
adseguy
Apr 21, 2006 11:50 AM
JDM97R
Dec 27, 2003 09:08 AM
margaflow
Jan 27, 2003 07:17 PM
