Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Check Gas Cap?
Old Jul 17, 2007 | 06:02 AM
nightryder21's Avatar
Default Check Gas Cap?
So my 06 Civic Lx starts to tell me "CHECK GAS CAP". So i pull over and check it. it seems to be in secure. So to make sure I opene it and close it again tight. I also make sure the hatch is properly closed. My car sill flashes "CHECK GAS CAP". Any of guys had this problem and/or know how to fix it? Its annoying cause it block the mileage info.
Old Jul 17, 2007 | 06:12 AM
pampass_pmw's Avatar
Default Re: Check Gas Cap? (nightryder21)
iIf you read the manual in the car it says that the message will go away in a set amount of time. I think it even mentions several days.
Old Jul 17, 2007 | 06:48 AM
Default Re: Check Gas Cap? (pampass_pmw)
damn. Thanks. It's just annoying that it blocks my mileage.
IT GUY's Avatar
it says something or other about 3 clicks too.. don't remember what exactly.. I'll take a look at lunch
Old Jul 17, 2007 | 09:00 AM
eLmO_2006's Avatar
Had the same issue. Had to take it to the dealership to have them reset as I drove for more than 50 clicks with the "Check Gas Cap" message!
Old Jul 17, 2007 | 09:11 AM
Hellzcivic's Avatar
Default Re: (eLmO_2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLmO_2006 &raquo;</TD></TR><TR><TD CLASS="quote">Had the same issue. Had to take it to the dealership to have them reset as I drove for more than 50 clicks with the "Check Gas Cap" message!</TD></TR></TABLE>
Not to highjack, but what the heck is a "Click". I know it is a military term used to describe a certain amout of distance, but what is that distance in normal measurement?
Thanks
Old Jul 17, 2007 | 09:18 AM
Default Re: (Hellzcivic)
Klick refers to one kilometre. click is what your gas cap does when you tighten it.
Klick (sometimes spelled click, which may also mean one minute of arc when adjusting the sighting system on a weapon such as a rifle) is a common military term meaning kilometer when referring to distance or kilometers per hour (km/h) when referring to speed. Its use became popular among soldiers in Vietnam during the 1960s, although veterans of the war recall its usage as early as the 1950s
Old Jul 17, 2007 | 01:51 PM
eLmO_2006's Avatar
typo, should have read "klick"!
Old Jul 18, 2007 | 09:36 AM
HRP4DoorSI's Avatar
It'll just block the mileage when you turn the car on. You can still cycle through your Trip A Trip B and Overall Miles if you want.
Same thing happened to me. It went away after about 25 miles. Next time I turned the car on, it was gone.
dnoonkeste
Aug 4, 2018 07:42 AM
bobinda808
Feb 29, 2012 05:03 AM
DougNuts
May 3, 2007 02:47 PM
