m24x cams
Old Jul 16, 2007 | 09:51 PM
azteggi's Avatar
Default m24x cams
hey guys,
anyone running these cams in their itr motor? i picked up these cams a few days ago. they will be going into my built itr motor.. how do they run? your input will be appreciated
Old Jul 16, 2007 | 10:16 PM
neo_'s Avatar
Default Re: m24x cams (azteggi)
Specs on your motor?
Old Jul 17, 2007 | 01:49 AM
Aquafina's Avatar
Default Re: m24x cams (neo_)
Haleiwa Brando ran them in his.
They like 2.0L, 12:1, a good header/im, and some CFM.
Old Jul 17, 2007 | 06:19 AM
azteggi's Avatar
Default Re: m24x cams (Aquafina)
specs are 81.5 mm weisco pistons. mugen head gasket, eagle rods.. supertech valve train. fuel pump. RMF header and will be putting a kteller 2.5 exhaust. tuned with hondata s300
Old Jul 17, 2007 | 06:20 AM
azteggi's Avatar
specs are 81.5 mm weisco pistons. mugen head gasket, eagle rods.. supertech valve train. fuel pump. RMF header and will be putting a kteller 2.5 exhaust. tuned with hondata s300. running around 12.1 compression
Old Jul 17, 2007 | 06:22 AM
Mr.OB*GYN_Rhett's Avatar
thats probably too big of a cam for you, m22xx
Old Jul 17, 2007 | 08:35 AM
itr1244's Avatar
Default Re: m24x cams (Mr.OB*GYN_Rhett)
that is what i got
m22 XX
i love it
Old Jul 17, 2007 | 08:37 AM
azteggi's Avatar
Default Re: m24x cams (itr1244)
cool. what is your setup?
Old Jul 17, 2007 | 08:40 AM
GO-FIGHT-KILL's Avatar
You're running Supertech valvetrain on stock cams?
Old Jul 17, 2007 | 08:42 AM
azteggi's Avatar
Default Re: (GO-FIGHT-KILL)
no. i picked up some rocket m24xx cams. but now im hearing that they might be a bit too big for my setup.. i can pick up some different cams if i need to
Old Jul 17, 2007 | 08:44 AM
JjuuN R's Avatar
Well, he probably planned on getting cams, so.
Better to run the Supertechs with stock cams then the m24xs on stock valves.
Old Jul 17, 2007 | 08:53 AM
azteggi's Avatar
Default Re: (JjuuN R)
i just want to make sure that these will be ok for my setup.. if not i can pick up something else and sell these.. i boght these brand new for 500
Old Jul 17, 2007 | 09:01 AM
itr1244's Avatar
Default Re: (azteggi)
my set up.
RM valve trains
RM M22-XX
CTR pistons 81.25mm (12.5ish c/r)
310cc
I/H/E
Modified by itr1244 at 1:18 PM 7/17/2007
Old Jul 17, 2007 | 09:18 AM
azteggi's Avatar
Default Re: (itr1244)
nice
Old Jul 17, 2007 | 09:35 AM
yeah what i said, dont do it. good for a 2liter with lots of compression
Old Jul 17, 2007 | 10:37 AM
itrSteez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azteggi &raquo;</TD></TR><TR><TD CLASS="quote">i just want to make sure that these will be ok for my setup.. if not i can pick up something else and sell these.. i boght these brand new for 500</TD></TR></TABLE>
How'd you get them brandnew for $500? do you have receipts? If you have proof they're the cam you say they are i'll consider picking them up.
Old Jul 17, 2007 | 11:35 AM
Aquafina's Avatar
Default Re: (itrSteez)
Unless he bought them new from someone who had already bought them, he didn't get them for 500 from any Rocket dealer. M24XX is far from ideal for your setup. I'd go with M22X.
Old Jul 17, 2007 | 11:38 AM
RhdRicheeee's Avatar
Default Re: (Aquafina)
AZTEGGI
You have M22xx NOT M24xx
Knuckle Head
Old Jul 17, 2007 | 03:03 PM
itrSteez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Unless he bought them new from someone who had already bought them, he didn't get them for 500 from any Rocket dealer. M24XX is far from ideal for your setup. I'd go with M22X.</TD></TR></TABLE>
going 84x89 now... so i'm trying to decided between m24's and pro2's.
Old Jul 17, 2007 | 04:16 PM
Aquafina's Avatar
I've you've got what I mentioned above, M24XX. If you have high comp (12.5-13+) M25X. I have a customer in Hungary using M25X on his 2.0 with 13:1 and he made around 20whp more than S2S3.
Old Jul 18, 2007 | 02:16 PM
itrSteez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">I've you've got what I mentioned above, M24XX. If you have high comp (12.5-13+) M25X. I have a customer in Hungary using M25X on his 2.0 with 13:1 and he made around 20whp more than S2S3.</TD></TR></TABLE>
check pm
jceltalentoso
Jun 19, 2012 10:31 PM
snaileg
K Series
Sep 4, 2010 10:58 PM
Teamdiesel
Jul 10, 2008 02:15 PM
azteggi
Feb 16, 2008 06:57 PM
jaydem_ekizzle
May 7, 2006 02:02 PM
