i plan to upgrade my race car but wich turbo?
Old Jul 16, 2007 | 09:45 PM
ivt-t's Avatar
Default i plan to upgrade my race car but wich turbo?
i am racing with a stock bore/stroke b16 engine
the engine is built 8,5cr eagle rods,je pistons,and so on.
it is running now with turbonetics 60trim turbo,60ar cold side,stage3 exhaust side,63ar
i need more power but i am afraid that bigger turbos would boost later,and may have a big lag.
Old Jul 17, 2007 | 02:54 AM
DaveF's Avatar
Default Re: i plan to upgrade my race car but wich turbo? (ivt-t)
the 42 on my racecar makes more power down low, then my t3/t67 did on my street car. and obviously kills the t3 uptop.
Old Jul 17, 2007 | 04:37 AM
ShawnR's Avatar
Default Re: i plan to upgrade my race car but wich turbo? (dturbocivic)
42r!
Old Jul 17, 2007 | 05:19 AM
tepid1's Avatar
S366 w/ the bigger turbine wheel or S372.
Old Jul 17, 2007 | 11:49 AM
Jay_Sensing's Avatar
When I had a turbo stock bore/stroke B16 in my last car, the largest I ever went was an SC6176e from Precision. Lag wasn't bad at all and the turbo made a lot of power up top. Granted it's not a huge turbo but it will support more than what you have now I believe and it was very livable.
Old Jul 17, 2007 | 12:12 PM
Boner_Ben's Avatar
Default Re: (Jay_Sensing)
Sounds like you would be happy with a GT35r.
Old Jul 17, 2007 | 01:04 PM
I B BANGGIN's Avatar
Default Re: (Boner_Ben)
i would stick witha t3/67 turbo..it would respond great to your mildly built set up and should make a pretty decent numbers on the dyno..
Old Jul 18, 2007 | 11:51 AM
ivt-t's Avatar
i have tryed 6176,but it spooled too slow.under 7000i cant get maximum boost.
Old Jul 18, 2007 | 11:52 AM
ivt-t's Avatar
i think that will be my choice.
Old Jul 18, 2007 | 11:59 AM
EG civic's Avatar
Default Re: (ivt-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivt-t &raquo;</TD></TR><TR><TD CLASS="quote">i have tryed 6176,but it spooled too slow.under 7000i cant get maximum boost.</TD></TR></TABLE>
You revved to 7000 and still didnt get full boost with a sc61???
Old Jul 18, 2007 | 12:17 PM
ivt-t's Avatar
Default Re: (EG civic)
no.
i get boost like this:
6000rpm 14psi
6500rpm 19psi
7000rpm 22psi
7500rpm 26psi
8000rpm 26psi
8500rpm 26psi
9000rpm 26psi
9500rpm 26psi
93first1
Apr 5, 2006 05:12 AM
bottlefedintegra
Dec 12, 2003 06:17 PM
Buzzbomb
Jul 2, 2003 10:09 PM
BLKCRX
Apr 23, 2003 01:13 AM
1996GsrVtec
Aug 21, 2002 07:49 PM
