input shaft bearing #12?
Old Jul 16, 2007 | 07:36 PM
static-x's Avatar
Default input shaft bearing #12?
taking the tranny out and needing to replace the input shaft bearing, is it number 12?
Old Jul 16, 2007 | 10:41 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: input shaft bearing #12? (static-x)
no, the input shaft bearing is not pictured in that image. it would be under number 10. it sits in the case. you pull the mainshaft through the input shaft bearing to get the mainshaft out.. if that makes sense.
Old Jul 17, 2007 | 04:44 AM
jlicrx's Avatar
#15 in this picture - you should also replace the seal #21
Old Jul 17, 2007 | 09:17 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: input shaft bearing #12? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">#15 in this picture - you should also replace the seal #21
Definitely. If you don't you'll regret it. &lt;---- Trans currently leaking because I didn't
Also, make sure to get the correct one for your year transmission. I've had probelm with different bearing sizes between 89 and 90-91 transmissions.
innes887
Nov 18, 2007 06:01 PM
Chiovnidca
Oct 24, 2005 04:30 PM
JDM SLICK
Apr 25, 2005 09:41 AM
HXvtec
Feb 6, 2004 05:17 PM
