How to tell if you have a Y1 LSD TRANNY?
Old Jun 9, 2002 | 09:40 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default How to tell if you have a Y1 LSD TRANNY?
I was wondering how can you tell if you have a LSD tranny. I have a y1 tranny and when I look thru the middle of it I see something in the middle. Does that mean I have a LSD tranny.
Old Jun 9, 2002 | 09:55 AM
Nighthawk GS-R's Avatar
New User
Default Re: How to tell if you have a Y1 LSD TRANNY? (Civicdrgrcr)
it says LSD on the tranny casing
Old Jun 9, 2002 | 10:02 AM
Default Re: How to tell if you have a Y1 LSD TRANNY? (Nighthawk GS-R)
But sometimes that LSD stamp comes off when they use all those chemicals at the warehouses to clean the eng, tranny's.
Old Jun 9, 2002 | 11:21 AM
Hard2Find's Avatar
Yes and NO.
Cable Tranny has "TWO" LSD markings on them.
#1. It has the LSD mark on ink.
#2. It has an ingrave (just like the block code) on the top..its very small letters (~12pt font size) that says LSD
also, if the tranny is out look through the hole where the axles go---you should see through it (NO bar blocking your way)
EDIT: If there is a bar through it---IT'S NOT LSD.
Good Luck
[Modified by Hard2Find, 2:23 PM 6/9/2002]
Old Jun 9, 2002 | 11:26 AM
Default Re: How to tell if you have a Y1 LSD TRANNY? (Hard2Find)
I suppose mine is not a LSD its just a str8 y1 tranny.
THankz
Old Jun 9, 2002 | 01:09 PM
EF'n's Avatar
jdm stock lsd tranny you will be able to look write throug the axle holes. that is the only way to tell unless you tear it aprart. bottom line pull out half shaft and axle and look throug to the day light.
Yuleluder
Dec 1, 2005 10:04 AM
de_sxc_b20_teg
Sep 20, 2004 02:21 PM
