Rod bearing size question...
Old Jul 16, 2007 | 07:30 AM
D.Dappa's Avatar
Default Rod bearing size question...
Spun a rod bearing on a gsr motor the machine shop said they took .020 off the crank. What acl bearings should I order? I know the honda bearings are sized differently but i'm going with acl since most people seem to think they are just as good in quality but almost half the price and acl bearings are sized differently. any help would be appriciated.
Old Jul 16, 2007 | 01:20 PM
slowcivic2k's Avatar
Default Re: Rod bearing size question... (D.Dappa)
If you can take it to a shop and have them take an inside micrometer to the crank bores of the block, and then an outside micrometer to the crank, you can figure out the thickness you will need, just to eliminate bearing matching problems. That is what I would do because I hate hit/miss fitting bearings until I get the right ones.
Old Jul 16, 2007 | 01:57 PM
D.Dappa's Avatar
Default Re: Rod bearing size question... (slowcivic2k)
yup i think thats a good idea i'll try that thanx man! Anyone else have a suggestion?
Charlie Moua
Jan 16, 2012 07:01 PM
red_99_lude
Nov 16, 2010 04:35 PM
acrocat
Jun 15, 2007 06:34 AM
OrangeBoost
Oct 19, 2005 06:14 AM
JeremyL
Jan 6, 2003 01:59 PM
