Pioneer Premier amp turning on and off
Old Jul 16, 2007 | 01:43 AM
FULL throTTLe's Avatar
Default Pioneer Premier amp turning on and off
i have a pioneer premier spl3000 amplifier, im trying to run it with my 15" diamond audio d9 at 1 ohm constant, my amp keeps turning on and off, and the sub pumps up and down, with or without the rca cable hooked up, do anyone know whats going on?? any help would be appreciated
Old Jul 16, 2007 | 06:49 PM
bump
Old Jul 16, 2007 | 08:48 PM
JTaudio0212's Avatar
Default Re: (FULL throTTLe)
Its like a heartbeat? Sometimes this will happen if the gain is turned up too high and the signal from the HU isnt giving the amp enough signal too work properly, are you using a high level input or an aftermarket HU? If a HU what kind and what is the voltage pre-out on the sub-amp?
It could be a bad input as well.
Old Jul 17, 2007 | 12:35 AM
stock head unit, using hi-low jack. amp is turned up 1/4 on the gain and freq
thats in my civic... when i plug it into my mustang, its a kenwood aftermarket deck, does the same thing, so im guessing it had to be the amp.
Old Jul 17, 2007 | 11:33 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
First I think you got the model number wrong. Is it this amp? PRS-D3000SPL. And if it is you need to wire that sub if you can. To a 2 ohm load. That amp does not support a 1ohm load. So you need to find a diffrent amp
http://www.pioneerelectronics....onent
Old Jul 18, 2007 | 02:05 AM
i think that could be the problem.... ok to wire a dual voice coil into a 2ohm how do i do that run it in series?
Old Jul 18, 2007 | 08:23 AM
You can't. You can either make that sub a 1 ohm sub like you have it now or make it a 4 ohm sub. Or you can sell that sub a buy a 4 ohm dvc sub and wire it parrale and make it a 2 ohm sub
Old Jul 19, 2007 | 12:18 AM
still does the same problem with 4ohms, i think its something internal with the amp. what do i do?
Old Jul 19, 2007 | 08:59 AM
I would look over the install. Try a diffrent amp if you can. If everything checks out send it in to pioneer for service. I hope you bought it from a dealer or its going to get pricey
Old Jul 20, 2007 | 12:24 PM
Default Re: (wrx-killer-Sti-eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">I would look over the install. Try a diffrent amp if you can. If everything checks out send it in to pioneer for service. I hope you bought it from a dealer or its going to get pricey</TD></TR></TABLE>
i dont have another amp that big to run it, and plus i dont know if i still have warranty, i bought it from magnolia hi-fi a long time ago
rountreesj
Audio / Security / Video
Dec 18, 2012 06:51 PM
superdat1
13
Jan 4, 2008 10:42 AM
ilikeric3
30
Sep 2, 2006 02:21 PM
Cory Matthews
22
Mar 6, 2006 02:13 PM
Jonathan_ED3
11
Jul 9, 2003 10:33 AM
