turbo d15
Old Jul 15, 2007 | 09:17 PM
crxricer66's Avatar
Default turbo d15
i ama thinking about building a custom turbo for my d15. i no custom wont be as good but i want sumthin to play around with. i have a crx hf manifold and i am getting either a ford probe turbo, or mazda 626,mx6. i also need to build my own bracket right?? then can i use a downpipe from a crx hf too?? or do i use one from sumthin else. if i do the turbo, do i need an msd ignition?? ive seen two that had the msd's. also do i need to do sumthin with the injectors right off, or will it still run fine until i do the mpfi swap. thx every1
Old Jul 15, 2007 | 09:58 PM
Reason's Avatar
im not trying to be an ******* or anyhting, but if you just go to the forced induction section of this forum then you will have every one of your questions answered without even having to post a topic. good luck with the build and take your time and do a lot of research. if you need any advice on anything just pm me.
Old Jul 15, 2007 | 11:40 PM
IP RACING's Avatar
Default Re: (Reason)
do mpfi first
Type-X
13
Feb 7, 2004 11:34 PM
frostt3ch
Apr 27, 2003 08:31 PM
BLuDoHcReX
Mar 12, 2003 10:28 PM
