1997 Accord EX engine Swap
Old Jul 15, 2007 | 07:22 PM
Canadianninja's Avatar
Default 1997 Accord EX engine Swap
i was wondering what will fit and whats the horsepower for each engine?
Old Jul 15, 2007 | 10:50 PM
rival12's Avatar
Default Re: 1997 Accord EX engine Swap (Canadianninja)
4cyl...you should really use the search feature, it's at the top right, in bright red....yeah...
anyways, before you get flamed more.
The swap which fits, and is direct bolt, i.e. no engine fabrication, direct drop-in. Wiring may be an issue depending where you get your motor (Usdm vs. JDM)
H22A (Prelude Motor) There's a few models of it. But factory specs generally say 195-205HP and 155-165TQ
You could also try F20B, but i wouldn't it's a little harder to find, more expensive, and i think the aftermarket products would be less.
You can also find an H22 with a limited slip differential (positrac; makes both wheels spin when one tire is slipping) i.e. most cars when one tire slips, it spins more, and the other tire does nothing, this insures both tires spin under slippage. Also better for accelerating around corners with the added pull.
GL
Old Jul 16, 2007 | 05:01 AM
TouringAccord's Avatar
H-T Order of Merit
Please search (it's been asked too many times) and check out the "Swaps" section of the Accord FAQ.
chinolal
Oct 27, 2019 04:34 PM
arctik06
Jan 14, 2009 12:13 PM
wingback44
Oct 11, 2005 06:59 PM
specialedition
Oct 21, 2004 03:25 PM
dezz
Aug 27, 2002 11:40 AM
