B16 Spurtin' Oil (first gen)
Old Jul 15, 2007 | 02:00 PM
Global688's Avatar
Default B16 Spurtin' Oil (first gen)
It looks like my B16 likes to spurt oil near the oil filter onto the lower frame behind it. Tried searching but mostly found ZOMG BUY THIS posts.
Only spurts under hard acceration and wont do it at idle or when I rev the engine.
Any ideas would most helpful thanks...
Car is a 91 civic sedan btw.
Old Jul 15, 2007 | 04:14 PM
jdmboyef9's Avatar
It could be the oil breather box. If the O ring is damaged than it can leak oil under high crank pressure. I have never heard of it spraying. It could also be a bad oil cooler which is what your oil filter bolts onto. If that's the case then I have one from a JDM ITR motor that I can sell but double check the O ring and the oil filter first
Old Jul 15, 2007 | 05:20 PM
Global688's Avatar
Default Re: (jdmboyef9)
Could be as I've been getting up on it more than a few times. Figured by now I'd have busted a hose if that was it.
Devon M
Jan 8, 2010 06:06 PM
jdm.ninja
Jan 2, 2010 04:50 PM
v8killaz
Nov 20, 2009 03:21 PM
Tim Martin
Feb 18, 2006 01:06 PM
Got_soy
Dec 23, 2005 03:41 PM
