FS: 626: NRG Hood Pin//NRG Engine Damper//Splash Lock//Xsite Audio Stuff
$70 - NRG Engine Damper for rsx (silver/new)
New never used, it was just sitting in the garage, because I couldn't use it due to the supercharger. Box got messed up, but all parts are there.
<FONT COLOR=""Red"">$25 - NRG Hood Pins (carbon fiber/new) - pending to speeddemon619 via clubrsx.com
</FONT>
$75 - Splash Lock w/ 2 keys (silver/used)
$125 each or $225 for both - (2) Xsite Audio XA4200 Amps (new)
* Class A/B MOSFET Power * Blue Anodized Heatsink with Laser Diamond Surface * Brushed Aluminum Case * High/Low Level Inputs * Bridgeable RCA Outputs * Variable High/Low Pass Crossover * Variable Bass Boost * Variable Subsonic Filter * Phase Shift * 4-way Protection * Blue Power Indicator * THD: 0.02% * 4-guage Power Inputs w/Screw Down Terminals * Optional Bass Remote and Digital Volt Meter * Single Sided Controls and Connections * Frequency Response: 10Hz-40 kHz * 2-ohm Stable * Dimensions: 8.88" x 2.13" x 14" * Power Output: 200 Watts RMS x 4 @ 4-ohms
$60 - Xsite DigitalCapacitor (new)
$40 per pair, $70 both pairs - (2 pairs) Xsite Components XSC525
5.25" components
Thanks for looking
</FONT>
5.25" components
Thanks for looking
