JDM Foglight bulbs in JDM ITR housings
Old Jun 9, 2002 | 05:32 AM
EVOTHIS's Avatar
Default JDM Foglight bulbs in JDM ITR housings
What size bulb does it take?
Old Jun 9, 2002 | 12:17 PM
98R-1144's Avatar
Default Re: JDM Foglight bulbs in JDM ITR housings (b18c ya)
use only 55w h3 bulbs
Old Jun 9, 2002 | 12:22 PM
NWPNOMORE's Avatar
Banned
Default Re: JDM Foglight bulbs in JDM ITR housings (98R-1144)
or else you will explode your fog light assembly if you use too high wattage bulbs.
Old Jun 9, 2002 | 01:09 PM
uNF$@#!'s Avatar
Default Re: JDM Foglight bulbs in JDM ITR housings (NWP4LIFE)
HIDs would work in there though
Old Jun 9, 2002 | 01:13 PM
sgT's Avatar
sgT
What kind of idiot are you?
Explode your fog light assembly? WTF
I use 110W H3 bulbs in mine.
Old Jun 9, 2002 | 01:22 PM
uNF$@#!'s Avatar
Default Re: JDM Foglight bulbs in JDM ITR housings (sgT)
actually sgt, he is correct. the yellow part of the housings so crack (i.e. explode). if you use the higher wattage bulbs. the heat stresses those parts.
if your housings have not been damaged yet, i would think its only a matter of time.
[Modified by 00-0187, 5:22 PM 6/9/2002]
Old Jun 9, 2002 | 01:24 PM
sgT's Avatar
sgT
Default Re: JDM Foglight bulbs in JDM ITR housings (00-0187)
Never seen it happen. A few of use use these high wattage bulbs.
I've had mine for oh lets see.... 5 years now. no cracking.
So you are testifying that the high wattage bulb will cause the yellow surround
to EXPLODE and break the outer housing?
Old Jun 9, 2002 | 01:26 PM
uNF$@#!'s Avatar
.... i've never seen someone so defensive about this sort of statement before.
what i will say is, i have seen numerous cracked housings due to overheating of those higher wattage bulbs.
Old Jun 9, 2002 | 01:29 PM
sgT's Avatar
sgT
Well, when you use a word like EXPLODE, then that connotates a violent result.
Something which I think a lot of people would take seriously.
I think the little yellow surround would crack, but the actual headlight housing
would be fine. Regardless mine are still like new(well as new as you can get
for 5 years of abuse)
Old Jun 9, 2002 | 01:37 PM
NWPNOMORE's Avatar
Banned
damn, look who the idiot it now. I've seen it happen many times to people who try to use higher watt bulbs. Maybe you should heed my warning before you ruin your set of headlights.
Old Jun 9, 2002 | 01:39 PM
sgT's Avatar
sgT
Lets see some pictures of these destroyed headlight housings.
Old Jun 9, 2002 | 01:40 PM
B2FiNiTY's Avatar
I forgot who had a thread with his fog lights busted. Goodfella on the board had that happen to him too.
Old Jun 9, 2002 | 01:41 PM
NWPNOMORE's Avatar
Banned
eat your words. Just apologize for being rude and it's all good.
[Modified by NWP4LIFE, 10:42 PM 6/9/2002]
Old Jun 9, 2002 | 01:43 PM
sgT's Avatar
sgT
Gee, it looks like its fine to me. Doesnt look like anything EXPLODED.
That headlight housing is still in perfect functional condition.
If you mean that stupid little yellow piece BROKE then you are right, anything
that small and thin can break. It can happen with 55w or 110w or just with age.
So stop it with your overdramatic garbage. EXPLOSION?? psha...
Old Jun 9, 2002 | 01:47 PM
NWPNOMORE's Avatar
Banned
whatever dude, i'm not gonna argue anything with you. You are the one that jumped all over me. All I was doing was giving this guy a heads up. But you are a Moderator so you are are right.
[Modified by NWP4LIFE, 10:52 PM 6/9/2002]
Old Jun 10, 2002 | 02:53 AM
EVOTHIS's Avatar
no more than I plan on using it I'll go with the 55 watt bulb, thanks.
Old Sep 11, 2007 | 05:32 PM
jdmmonkey's Avatar
Default Re: JDM Foglight bulbs in JDM ITR housings (EVOTHIS)
My foglights exploded on me from using high wattage bulbs.. so yes it can happen and probably most likely will happen..
Old Sep 11, 2007 | 05:37 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM Foglight bulbs in JDM ITR housings (jdmmonkey)
And you really dug up a 5-year-old thread to post that info?
Old Sep 11, 2007 | 08:02 PM
[Ennis_D]'s Avatar
Default Re: JDM Foglight bulbs in JDM ITR housings (Padawan)
Just some FYI but the bulb sizes for each light are posted/written on the outer headlight covering...Or atleast there are on mine
Old Sep 11, 2007 | 09:39 PM
Spoon ITR's Avatar
Default Re: JDM Foglight bulbs in JDM ITR housings (Trock1029)
talk about coming back from the dead...this is like 5 years old
runhopskipendub
Honda Fit
Oct 11, 2007 09:04 PM
Beave0101
Mar 7, 2003 11:38 AM
ifactor01
Jan 18, 2003 11:14 AM
MoJoJoJo
Jun 23, 2002 06:27 PM
intevic2010
Oct 16, 2001 09:34 PM
