Gsr Block..Which head?
Old Jul 15, 2007 | 10:32 AM
bullet647's Avatar
Default Gsr Block..Which head?
I'm keeping all internals stock but i have all the parts and was wondering if i should keep my gsr motor complete block and head or should i use the gsr block and b16 head?
Old Jul 15, 2007 | 10:44 AM
sauceja's Avatar
Default Re: Gsr Block..Which head? (bullet647)
If you have a GSR then keep it that way.
Why not swap some ITR or B16 JDM pistons in there to give it some umph.
Old Jul 15, 2007 | 11:49 AM
nokturnal_munkeeboy's Avatar
stay with the gsr head and put some p30 or jdm itr pistons in your motor.
Old Jul 15, 2007 | 05:12 PM
bullet647's Avatar
Default Re: Gsr Block..Which head? (nokturnal_munkeeboy)
i not planing to change any internals just was curious which was the better setup to use with my gsr block...the gsr head or b16 head...
Old Jul 15, 2007 | 08:36 PM
jdmboyef9's Avatar
GSR head has higher compression and will make more power in stock form
Old Jul 15, 2007 | 09:19 PM
just stay with gsr head. if you build your head you will have good numbers. little pnp upgrade your valves and get some aggresive cams. some good tuning
408EJ1
16
Jan 8, 2014 03:23 PM
xxnuttybarxx
Oct 25, 2007 01:04 PM
jdmgeezer
Oct 19, 2007 09:01 AM
racingfan
13
Sep 6, 2005 02:09 AM
Tyson Ballou
Dec 26, 2001 06:17 PM
