Starting trouble....Please help!
I have a 91 Civic Si and I can't find out why it won't start. It will turn over just fine, but it seems like it's not getting any fire. Here's what happened, I started one day and it ran for about a second or two then died. It didn't make any sound, it was like I turned off the key. Here's what I have check and changed... I checked all of the fuses, loosened the bolt on the fuel filter to see if it was getting fuel, checked the timing, just to make sure it didn't jump time, replaced the plugs and turned it over and removed one of the plugs to see if it was getting gas and the plug was wet from gas. I have replaced the distributor cap, the rotor button, igniter, coil, and the distributor its self. And it STILL won't start. Am I over looking something? Any ideas will help. Thanks!
platinum_rich
15
Feb 25, 2012 08:16 PM
JimmyM86
Oct 23, 2007 06:15 PM
