98 lx timing belt/crank pulley bolt help
Old Jul 15, 2007 | 08:49 AM
01celica_gts's Avatar
Default 99 lx timing belt/crank pulley bolt help
i'm in the middle of taking replacing the timing belt, everything has been smooth so far, now i'm stuck, trying to take out the crank pulley, the crank pulley bolt keeps on turning, when i try to take it out. any suggestions??
Modified by 01celica_gts at 10:22 AM 7/15/2007
Old Jul 15, 2007 | 08:54 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 98 lx timing belt/crank pulley bolt help (01celica_gts)
It's loose but it just turns instead of backing out when turning it?
Old Jul 15, 2007 | 08:58 AM
Default Re: 98 lx timing belt/crank pulley bolt help (TouringAccord)
it's loose/just turns, but not coming out..
Old Jul 15, 2007 | 09:10 AM
IK_Noodle's Avatar
Default Re: 99 lx timing belt/crank pulley bolt help (01celica_gts)
you need a special tool the holds the crank pulley in place while you undo the bolt. if you go on tasauto.com you can find it. im sure you could buy it other places but that will let you see what you are looking for.
Old Jul 15, 2007 | 09:12 AM
H-T Order of Merit
wait, the bolt itself turns while the pulley is being held in place or the bolt and pulley is turning while you are doing this?
newlude8657
May 3, 2012 10:29 PM
socialistic
31
Jun 26, 2011 12:54 PM
ryanangelo212
May 23, 2009 08:36 PM
93gsrcoupe
Sep 30, 2004 09:54 PM
Milano97
Jun 2, 2002 04:59 PM
