LS/VTEC fuel problems
Old Jul 14, 2007 | 07:34 PM
B Series JuNky's Avatar
Default LS/VTEC fuel problems
i have a 91 acura integra with an LS/VTEC and it was running fine before but now its not passing gas ? i checked my fuel pump and i can hear it turn on my anything else i can check thanks for any help u guys give me..
Old Jul 15, 2007 | 09:50 AM
Default Re: LS/VTEC fuel problems (B Series JuNky)
can my injectors be messed up ??/
Old Jul 15, 2007 | 02:03 PM
would my fuel pump still turn on if it doesnt work ?
Old Jul 16, 2007 | 03:19 AM
dannylDAsport's Avatar
check fuel pressure what makes u think its a fuel problem? check for spark.
Old Jul 17, 2007 | 07:18 PM
Default Re: LS/VTEC fuel problems (dannylDAsport)
its a fuel problem because i dont hear fuel going threw my injectors and my fuel gauge doesnt fill up like it should
Old Jul 17, 2007 | 09:50 PM
tunerkid07's Avatar
if u think its fuel, go to your fuel rail, theyre be like a 23mm bolt, loosen it, have someone stand about 4 ft away from the motor n turn the key on but dont start it, if fuel comes out of that line...well then your fuel is fine, or it can be a relay, check your fuel pump relay n see if its fried or what...
Old Jul 17, 2007 | 09:54 PM
Suck my DX's Avatar
Default Re: (tunerkid07)
so are your injectors not working or are you getting no pressure to the rail?
Old Jul 18, 2007 | 11:02 AM
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">so are your injectors not working or are you getting no pressure to the rail?</TD></TR></TABLE>
yeah im gettin no pressure to my fuel rail and i dont hear my injectors sprying gas... i could hear my fuel pump turn on and im running my fuel relay direct power
Old Jul 18, 2007 | 11:10 AM
Default Re: (B Series JuNky)
i went to buy a fuel filter today and nothing yet i mite go buy some injectors see if that helps
Old Jul 18, 2007 | 11:30 AM
i losed the fuel line that gose to the fuel rail and i turn the key on to where gas should flow but no gas was coming out of the fuel line ??
Old Jul 18, 2007 | 11:37 AM
Suck my DX's Avatar
well its one of two things then. either your fuel pump is no longer good or your fuel lines are clogged...
are you sure the fuel pump is turning on?
Old Jul 18, 2007 | 08:17 PM
yeah its turning on i have my fuel pump relay direct power and i can hear it on
Old Jul 18, 2007 | 09:34 PM
tunerkid07's Avatar
trace your fuel line n make sure u dont have any kinks in it... if u still cant find the problem, play swaptronics, pull your injectors n try another set, if dosnt work then change to the regular ones n u probably have a wirin problem or somethin then, what block and head?
Old Jul 19, 2007 | 10:49 AM
b18b block, pr3 head i dont think it's a wire problem
Old Jul 19, 2007 | 04:41 PM
tunerkid07's Avatar
have u double checked everything on your head? all the lines, electircal, and fuel relays?
like the other guy also said it also may be a cloged fuel line... r u sure your injectors arent workin?
Old Jul 19, 2007 | 05:15 PM
my injectors arent working i dont hear them sprying gas...and my fuel relay is ran direct
Old Jul 19, 2007 | 10:20 PM
tunerkid07's Avatar
get another set of stock injectors n try it then, just play swaptronics, if u dont think one thing is working swap it out n see if u get ne thing, r u leakn any? sure u have the lines correct? check your injectors, is there splices in the wires to the clip?
Old Jul 19, 2007 | 10:39 PM
Suck my DX's Avatar
you dont listen for spraying gas when checking injectors...youlisten for te ticking sound...use a long screwdriver to listen if they are operating...either way if theres no fuel in the line they wont have anything to spray...
once again i gotta ask you, are you sure your getting no pressure to the rail?
if your not its either cuz your fuel pump is not working or the lines clogged...
can you hear the fuel pump turn on when you give it direct power?
Old Jul 20, 2007 | 10:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">you dont listen for spraying gas when checking injectors...youlisten for te ticking sound...use a long screwdriver to listen if they are operating...either way if theres no fuel in the line they wont have anything to spray...
can you hear the fuel pump turn on when you give it direct power?</TD></TR></TABLE>
i unlosend the gas line that hooks up to the fuel rail and no gas came out whats so ever... and yeah i can hear the fuel pump being on with direct power.. how do i hear the ticking from the injectors with a screwdriver can u give me the run down on that please...
Old Jul 20, 2007 | 10:13 AM
if my fuel line's are clogged what can i use to un clog them ?
Old Jul 20, 2007 | 03:03 PM
tunerkid07's Avatar
put the tip of the screwdriver on the injector, n as for your line cloged, just say screw it n upgrade your fuel lines.... better down the line neway especially if u wana build your motor
Old Jul 20, 2007 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid07 &raquo;</TD></TR><TR><TD CLASS="quote">put the tip of the screwdriver on the injector, n as for your line cloged, just say screw it n upgrade your fuel lines.... better down the line neway especially if u wana build your motor</TD></TR></TABLE>
on what tip of the injector where it sprays or what
Old Jul 21, 2007 | 05:41 PM
tunerkid07's Avatar
tp of the screwdriver on the injector n the end near your ear for u to listen to it
Old Jul 23, 2007 | 05:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid07 &raquo;</TD></TR><TR><TD CLASS="quote">tp of the screwdriver on the injector n the end near your ear for u to listen to it</TD></TR></TABLE>
alright i'll try that
Old Jul 28, 2007 | 10:48 AM
i tried that screw driver **** couldnt hear nothing from the injectors
