Offset boring rods?
Is is possible to have rods offset bored on the big end. Similar to re-sizing the big end, but have the bore moved up towards the small end? I'm thinking about making a B18C 137.9mm rod have an effective length of 137mm. ARP bolts taking it up to 8k used for daily/RR. Would it work?
Offsetting the centerline of the pin bore is the only way to do it. Youd have to use smaller pin and move it up or down however much material will allow with your choice of pin diameter.
jetlude
Jan 28, 2008 03:42 AM
CRX Lee
Feb 9, 2004 08:39 AM
