crx tranny problem
Old Jul 14, 2007 | 05:20 PM
slowcrx954's Avatar
Default crx tranny problem
i have 91 crx with a b18ablock with a blown y1 b16 tranny.but i ran into a problem when swaping out the b16 trans for a used ls.the splines are totally diffrent,do i have to get a new clutch and axles?also i now seeing that i might have a 94 and up ls trans but i thought they were all hydro,but i have a cable one. please help i dont know what to do!!!
Old Jul 14, 2007 | 07:23 PM
B16A CRX's Avatar
Default Re: crx tranny problem (slowcrx954)
i think 92 and up Ls tranny is hydro. unless you have a hydro to cable conversion you cant use it. And as for the axles and the half shaft you have to have the same year halfshaft and axles. meaning if you have a 91 integra halfshaft you need 91 integra axles.
Old Jul 14, 2007 | 08:10 PM
mr.speaker's Avatar
Default Re: crx tranny problem (B16A CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">i think 92 and up Ls tranny is hydro. unless you have a hydro to cable conversion you cant use it. And as for the axles and the half shaft you have to have the same year halfshaft and axles. meaning if you have a 91 integra halfshaft you need 91 integra axles. </TD></TR></TABLE>
94 and up is hydro..
it sounds like you have a 92-93 cable ls tranny,,they are different then the pre 92 cable trannys and need a different clutch (1992 integra)...you can re-use what ever axles you used with the b16 tranny...
Also you'd know if the tranny was hydro,there would be a slave cylinder on it ,,or atleast a place to mount one
Old Jul 14, 2007 | 09:02 PM
slowcrx954's Avatar
Default Re: crx tranny problem (mr.speaker)
so i need a clutch,but i tried to dry fit the axles but they seem they dont want to fit.
standbackimapro
Nov 29, 2007 09:08 AM
MHBb16CRX
Jun 28, 2007 01:34 PM
my91hatch
14
Nov 21, 2006 03:30 PM
nomotor
Oct 20, 2004 05:38 PM
st00pid
Oct 5, 2004 09:39 PM
