headgasket for h22a
Old Jul 14, 2007 | 01:43 PM
kornerk12's Avatar
Default headgasket for h22a
I have a HG for an h22a4 however i have a friend that needs a gasket for his jdm h22a. Will the a4 gasket work on the h22a ?
Old Jul 14, 2007 | 03:21 PM
Eddiebx's Avatar
Default Re: headgasket for h22a (kornerk12)
from waht i rmember, the a4 gakset is differnent from the jdm h22a and h22a1 gaskets because of the open vs closed deck
Old Jul 15, 2007 | 08:12 PM
kornerk12's Avatar
Default Re: headgasket for h22a (Eddiebx)
bump
Old Jul 15, 2007 | 08:25 PM
typeSwarrior's Avatar
I concur...they are two different gaskets, and I've seen the visual differences between the two.
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">from waht i rmember, the a4 gakset is differnent from the jdm h22a and h22a1 gaskets because of the open vs closed deck</TD></TR></TABLE>
right.
you should use the gasket that the block requires. If you have an open deck block, use the open deck headgasket. same with closed deck.
stevewoods812
Mar 19, 2010 08:24 PM
mooney8289
Jan 26, 2010 07:07 PM
tegh22
Oct 14, 2008 12:46 PM
rcoolb2002
Jun 29, 2006 06:21 PM
