pcv hose collapse
Old Jul 14, 2007 | 12:58 PM
coolusername's Avatar
Default pcv hose collapse
i noticed the hose going from the pcv valve is collapse. do i just need a new hose, or is there a problem with the pcv valve. thanks
Old Jul 14, 2007 | 01:42 PM
BlueCrxNC's Avatar
I'd replace the vacuum hose and the PCV Valve (~$5 new)... might as well put new lines everywhere as they are all looking a little old.
Old Jul 14, 2007 | 01:45 PM
thesmogman's Avatar
Default Re: pcv hose collapse (coolusername)
The best thing to do is replace them both. The PCV valve is always forgotten about. The ECU is compensating for the flow thru the pcv valve. When it is collapsed the air is not getting into the manifold so there is less air mixing with the gas and causing a rich air/fuel ratio.
zeroek
Apr 3, 2011 04:07 PM
vietnamese0utlawz
May 19, 2006 09:46 PM
killah3084
Nov 13, 2005 02:42 PM
Ri5e
Jun 28, 2002 11:32 AM
