tranny flush
Oh yeah, if its a manual you'll see a plug that you can fit a 17mm wrench on several inches above and slightly rearward of the drain plug. Remove that, but save the washer, and reinstall the drain plug. Fill the trans. until fluid starts to spill out of the fill hole, then replace the fill hole plug (with the washer). Get 3qts to be safe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatterMatt »</TD></TR><TR><TD CLASS="quote">You fill it in the dipstick hole. You'll need a long funnel, or one with a tube on it... </TD></TR></TABLE>
Just wanted to add that any auto parts store will carry funnels designed to fit into automatic transmission dipstick holes.
northkai3
26
Sep 29, 2013 11:53 AM
but I think its 4 or 5ish
