m2b4 lsd Tranny Question
Anyone with a M2B4 Tranny ever replaced the oil seal that faces the driver wheel?, Has anyone installed a US tranny seal on it?, I bought a seal from the dealer , I told them it was an h22 tranny, it fits but not tightly, and it leaks, has anyone replaced it and not had any problems, I need to make sure Its the right size seal so I can get a sleeve to make it seal, or buy the right size one.
if your talking about the axle seal, yes the usdm seals are the same.
instead of telling them its an h22 tranny, tell them its a honda prelude transmission and you need the drivers side axle seal.
Yeah Im refering to the seal on the tranny where the axle inserts, and when I purchase parts at the local honda dealer, they ask what model, so I told them it was an si vtec, so you've personally used a usdm seal on a jdm tranny ?,if so, then I guess something is wrong with my tranny, which could be, my case was repaired. I was 2 seconds away from buying a jdm seal, thinking it would be slightly bigger, Thanks for the help.
h22zexhatch
Jun 22, 2005 10:29 PM
AgentJam
Oct 16, 2003 04:03 PM
