SKunk 2 Stage 2s Question
Is there a problem running this with stock compression on a b18c1 gsr? Is there a way to boost compreesion with these cams without having work done to the block? Thanks in advance
Flat faced valves will help by about 0.2 compression. 2 layer headgasket. Carbon buildup on pistons lol.
You are not going to get a significant bump in compression without different pistons.
You can also mill the head to raise compression. I had my head milled .030 which brings compression up about .5. So if you mill the head, get flat faced valves, and a thin head gasket like from Spoon, you will get a nice bump to about 11.0. But like b19coupe said, stock compression is fine with these cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Skunk Stage 2's are fine with stock GSR compression.</TD></TR></TABLE>
i thought skunk stg 2's like about 11.3+ compression though people also put them in ITR's with 11.1 and make power
p30 pistons are bigger then usdm/jdm itr pistons
erm how are these cams in a poor mans type r with CTR pistons?
for all that dont know
gsr block with ctr pistons 2 layer spoon gasket and b16 head
Listen to B19, forget trying to increase compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">p30 pistons are bigger then usdm/jdm itr pistons
gsr block with ctr pistons 2 layer spoon gasket and b16 head</TD></TR></TABLE>i'm still tring to figure out what the hell your talking about?
stage 2's should be fine with gsr CR, but if you want to go all out some flat faced valves, 2 layer head gasket and milling the head a bit will bump your CR without spending money on forged pistons
It's not that it's to much, but it's not required as stated by so many other experienced people in this thread. Increasing compression like that without need will only make it harder to tune. Skunk says 11:1 is ideal for those cams, many people run less and make good power, running more compression isn't going to make that much difference.
well the only thing is that my rings are bad and im burning oil so I was gonna rebuild the bottem end. I wanted to do it once and right so I figured the high compression wouild aide me donw the line if I ever wanted to upgrade the cams
For sure, just don't need to go overboard. Anything from 10.5-11.5 is great for street daily driven cars. Forget the CTR pistons, just go with the PR3 or P30 pistons, you'll be happy with them. You'll have enough compression to run most of the common good power cams out there.
No they are not pro series. Cams affect dynamic compression but that's not what's being discussed here. You typically match your static comp ratio to your cams requirements for that reason.
DaWhiteCoupe
May 18, 2005 11:38 AM
sikciv666
May 22, 2004 07:06 AM
