code 4/10/14/15...HELP!!..91 dx obd1 ls
ok this is what i have, A 91 dx sedan MPFI swap, obd1 ls head, xecron obd1 jumper harness, i started it up today and it ran like a bag of ****..Now ive been reading that 15 is ignition output signal..Which basically could ba an ignitior..But b4 i left my shop I swapped but to my obd0 LS dizzy and i still had all the same codes?..
also the code 4 crank postion sensor...
c0de 10 iat sensor, and code 14 IACV which im assuming i just swaped the plugs..
so Now im wondering maybe the jumper harness is pinned wrong?...
any help would be great guys.
did u depin the original c1 and c2 wires and swap them over to b10 and b12 positions, then run wires from c1 and c2 to the distibutor... c1-blu/grn & c2-blu/yel
update...
well when i reset the ecu and actaully sodered the ignition output siganl wire all the codes went away except code 10...
that code stuck around the whole time, when i had first done the obd0 mpfi swap...im just goin to run the wires right from the sensor to the ecu
dephtone
36
Jul 21, 2009 11:02 AM
