will this header fit
Old Jul 13, 2007 | 04:07 PM
Redemption's Avatar
Default will this header fit
Will a header off of a 00 Si fit my 99 LS?
Old Jul 13, 2007 | 04:13 PM
SleeperGSR's Avatar
Default Re: will this header fit (Redemption)
prety sure that it wont...
Old Jul 13, 2007 | 04:24 PM
Redemption's Avatar
Default Re: will this header fit (SleeperGSR)
This guy is selling a greddy header off of a 00 Si at a descent price and I was thinking to pick it up for my ls.
Old Jul 13, 2007 | 04:30 PM
no2unenolife's Avatar
i believe that the flange from the engine will bolt up correctly, but the length will be off so you might have to modify your exhaust piping
Old Jul 13, 2007 | 05:22 PM
posHonda's Avatar
it will bolt up just fine but youre most likely going to have to modify the exhaust because of the length.
Old Jul 13, 2007 | 05:35 PM
Redemption's Avatar
I'm going to be running a test pipe.
Old Jul 13, 2007 | 06:33 PM
TurbdEG6's Avatar
Default Re: (Redemption)
test pipes are usually made to be the same length as your stock cat
Old Jul 13, 2007 | 08:07 PM
Redemption's Avatar
So I shouldn't risk getting it?
Old Jul 13, 2007 | 10:31 PM
DB1_559's Avatar
i used a b17 dc sport header on my ls,didnt mod anything i just pulled the cat to the header like 2in off,but it worked no problem
Old Jul 14, 2007 | 10:03 AM
1turbodc2's Avatar
it won't b16 has a lower deck highet and the flang for the cat is different.
Old Jul 14, 2007 | 11:43 AM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redemption &raquo;</TD></TR><TR><TD CLASS="quote">So I shouldn't risk getting it?</TD></TR></TABLE>
if it dont work sell it to me ill make it fit
Old Jul 14, 2007 | 01:27 PM
Redemption's Avatar
I picked it up for $50 dollars and cleaned up so it looks like brand new with a guide that I found on TI. It also had barelly any scrappes on the bottom and there are no craks. I'm gonna try it hopefually sometime next week. If it doesnt work then I will know for next time. If it does but the flange is the problem I dont mind driving with open header till I figure something out.
Old Jul 14, 2007 | 01:40 PM
1turbodc2's Avatar
i have an 2000 SI and had an 01 gSR i will tell u right now it won't be flush on the head, and you will have a nasty exhaust leak i know, cause i took my stock SI exhaust mainfold and tried to put it on my gsr and i had a big *** exhaust leak! so if you want to waste your time and money go for it
Old Jul 14, 2007 | 01:43 PM
Redemption's Avatar
Thanks bro.
Old Jul 14, 2007 | 03:43 PM
DB1_559's Avatar
Default Re: (1turbodc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1turbodc2 &raquo;</TD></TR><TR><TD CLASS="quote">i have an 2000 SI and had an 01 gSR i will tell u right now it won't be flush on the head, and you will have a nasty exhaust leak i know, cause i took my stock SI exhaust mainfold and tried to put it on my gsr and i had a big *** exhaust leak! so if you want to waste your time and money go for it</TD></TR></TABLE>
but thats a stock manifold
$amGD3
Aug 29, 2010 05:46 PM
recon23
Jul 13, 2009 05:10 PM
SCIVIC94
10
May 16, 2005 05:44 PM
dc2Rgirl
Dec 1, 2004 06:51 PM
BlueIntegraBoy
Jul 30, 2003 05:56 AM
