YS1 tranhy from B17?
Old Jul 13, 2007 | 03:51 PM
BukakkEK9's Avatar
Default YS1 tranhy from B17?
OK so i got a b17 tranny, b/c my b16 tranny craped out, my question is whill the b17 tranny fit on the b18C clutch? or will i need to get another clutch. I had this issue with my old D series b4 im just makeing sure i dont have an issue with this one. Any info u guys can provide would be greatly appreciated.
Old Jul 13, 2007 | 05:08 PM
4thgenhtch's Avatar
Default Re: YS1 tranhy from B17? (BukakkEK9)
So you have a b18c hydro tranny now?
If thats the case then you will need a cable pressure plate, then yes, You can use the bigger splined hydro disk with the b17 cable tranny...
If not I need more specific info... You say your b16 trans crapped out but you already have a b18c clutch???
Old Jul 13, 2007 | 06:24 PM
godruler's Avatar
Default Re: YS1 tranhy from B17? (4thgenhtch)
not only do you have to use a 92-93 cable pressue plate but you also need the throwout bearing. you cannot use the hydro throwout bearing on a cable tranny.
Old Jul 13, 2007 | 06:39 PM
Crx Jimmy's Avatar
Default Re: YS1 tranhy from B17? (godruler)
you can use any b-series pressure plate, and any 92 up disc, they are all the same. you WILL need a 92-93 integra throw out bearing
Old Feb 24, 2012 | 06:02 AM
2000-em1's Avatar
old post but im confused about this... what if the tranny was converted to a hydro?
Old Feb 24, 2012 | 06:14 AM
Deetz's Avatar
Crazy Honda Guy
"ALL" 1992-2001 b series tranny's regardless of cable of hydro use the SAME clutch!!
Meaning pressure plate and disk. I don't know about the release bearing, but think the cable one is slightly different than the hydro design
Old Feb 24, 2012 | 06:18 AM
2000-em1's Avatar
My bad I was asking toward the tob
christion
Aug 9, 2006 11:38 PM
lilxvtecxpwr
Feb 11, 2005 11:47 AM
phrasathane
Feb 10, 2004 05:48 AM
chulopilong
Feb 14, 2003 04:37 AM
