single stage sanding
Old Jul 13, 2007 | 03:20 PM
postman's Avatar
Default single stage sanding
before sparying a car with single stage. what should the final grit of sanding be. planned on spraying a sealer or primer/sealer first?
Old Jul 13, 2007 | 03:41 PM
WihaSi's Avatar
Default Re: single stage sanding (postman)
I would suggest spraying a sealer before you lay down color, that's just me. Typically I would finish with 600 or 800 grit wet, if sanding filler primer. If you are just spraying over top of old paint with no repairs you can use a scuff pad and sanding paste or sand it with 1000 grit.
thomasEG
Paint and Body
13
Jan 31, 2013 06:11 PM
tasco
Paint and Body
Nov 13, 2011 09:27 AM
EatSleepJDM
Paint and Body
24
Apr 7, 2009 06:42 AM
downeyballz
Paint and Body
Jan 26, 2008 09:06 AM
trecool44
Jul 18, 2006 03:18 PM
