Buddy club Spec IV cam datasheet needed!
I don't have one and the Buddyclub distributers in UK/Europe are being less than helpful!
Would anyone be willing to email any of the literature that should of come with them?
Cheers in advance!
Cheers in advance!
From the buddyclub website(buddyclub.us)
SPEC IV
*Dyno Tested
250HP
235TQ
B18C1 Engine
$688.00
TIMING
DURATION
VALVE LIFT
VALVE CLEARANCE
1mm OPEN
1mm OPEN
INLET
37° BTDC
49° ABDC
306°
12.3mm
0.007
1mm OPEN
1mm OPEN
EXHAUST
61° BBDC
21° ATDC
302°
11.8mm
0.008
SPEC IV
*Dyno Tested
250HP
235TQ
B18C1 Engine
$688.00
TIMING
DURATION
VALVE LIFT
VALVE CLEARANCE
1mm OPEN
1mm OPEN
INLET
37° BTDC
49° ABDC
306°
12.3mm
0.007
1mm OPEN
1mm OPEN
EXHAUST
61° BBDC
21° ATDC
302°
11.8mm
0.008
Ive found this stuff, need some data on the actual setting up of them though? Ive been led to understand that they should of come with some data regarding basic settings (before tweaking) for the cams to run. i.e not TDC 0 degrees but advanced/retarderd? I may be wrong of course! But im severely doubting they run standard timing!
Cheers for any assisstance in advance!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclipsed4ever »</TD></TR><TR><TD CLASS="quote">Ive been led to understand that they should of come with some data regarding basic settings (before tweaking) for the cams to run. i.e not TDC 0 degrees but advanced/retarderd? I may be wrong of course! But im severely doubting they run standard timing!</TD></TR></TABLE>
i've yet to see any cam manufacturer included a "recommended cam gear setting" sheet. it would be nice, but i don't think that they exist. i think its safe to assume that most, if not all cam manufacturers expect the buyer/user to tune his/her motor after the cam install. i mean, it is 08'. and to completed honest, that paper is supplied with the cam. all the information needed to degree the cams are supplied. g/l
If the 96* Intake and 110* exhaust are correct and there hasn't been much if any milling of the head or decking of the block and a 3 layer headgasket is being used, you would install the cams at +2 Intake and 0 exhaust (that's CAM degrees, not crank degrees). Then you'd start tuning on a dyno from there for best power.
It's just math that you use to install any camshaft as long as you know the centerlines. It's what you start with when checking clearances and tuning on the dyno.
Stock cam intake centerline = 98*
Buddy Club IV = 96*
so to equal stock centerline you have to add 2 degrees = +2
Stock exhaust cam centerline = 110* and so does the Buddy Club IV cam so no correction is needed and you start at 0* on the cam gear.
Buddy Club IV = 96*
Buddy Club IV = 96*
Buddy Club IV = 96*
Buddy Club IV = 96*
Buddy Club IV = 96*
sorry but i cant find these stock vtec centerline for years...Where did you find them bro?
Turbo E
Aug 17, 2004 03:18 PM
canuck-mx6
Mar 7, 2002 11:50 AM
