B20Z2 OBD2 in a OBD1 94 TEG; need wiring help
Old Jul 13, 2007 | 08:16 AM
Jabinya's Avatar
Default B20Z2 OBD2 in a OBD1 94 TEG; need wiring help
I've done engine swaps before but only within the same OBD range. Now I have a OBD2 B20Z2 that is going into a OBD1 1994 Integra and am unsure on what I need to do to get this working correctly.
The ECU that will be used is a OBD1 P75 LS ECU. I have the B20Z2 OBD2 engine wiring harness that connects the the chassis harness. My chassis to ECU harness is OBD1.
Am I going to have to chop the harness and rewire everything or is there a conversion harness that would work on my application?
Old Jul 13, 2007 | 08:30 AM
turbo93da's Avatar
Default Re: B20Z2 OBD2 in a OBD1 94 TEG; need wiring help (Jabinya)
you should not have to chop anything
the alternator should be switched and the intake manifold with all accersories
everything else should plug up then you will not be using the secondary cps
Old Jul 13, 2007 | 09:14 AM
Jabinya's Avatar
Default Re: B20Z2 OBD2 in a OBD1 94 TEG; need wiring help (turbo93da)
It already has a OBD2 alternator. Should I switch to a OBD1 alternator?
Luckily, there is a 94' LS IM sitting next to me. So I have that covered.
What about the distributor? Will that be plug and play?
Old Jul 13, 2007 | 01:26 PM
GSR-TRBO-DA's Avatar
if you are putting it in to a obd1 chassis then you are going to need the obd1 distibutor, alt., the stock harness, Ls im, tb, and probably the driverside motormount, and bracket to make the b20 work. no cutting involved and even if there would be you always want that to be your last resort.
Old Jul 14, 2007 | 06:18 AM
Jabinya's Avatar
Default Re: B20Z2 OBD2 in a OBD1 94 TEG; need wiring help (GSR-TRBO-DA)
Thanks for the info! So here is what I have so far;
LS IM
94' LS driver's side motor mount
Stock harness
94' LS TB
I have a OBD1 D series alternator and distributor but I'm not sure they will work. Am I missing anything?
Anyone have a link to a tutorial on this kind of swap?
Old Jul 14, 2007 | 08:05 AM
turbo93da's Avatar
you can manipulate the alternator from d series to fit but not distributor only ls will work right
Old Jul 14, 2007 | 11:30 PM
Jabinya's Avatar
I double checked my dizzy and alternator and found that they are both OBD1. I guess the guy who had this before me already put these on. Even had a OBD1 power steering pump. Cool. Less money I have to spend. Thanks guys.
Old Jul 15, 2007 | 04:45 AM
DC2R_JOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-TRBO-DA &raquo;</TD></TR><TR><TD CLASS="quote">if you are putting it in to a obd1 chassis then you are going to need the obd1 distibutor, alt., the stock harness, Ls im, tb </TD></TR></TABLE>
WRONG!
Ive done lots of swaps into EG's, DC's.. You can use OBD2 engine harness in the chassis, even though it is OBD1! You just have to use the OBD2 distibutor, alt, im!! and you can still use your OBD1 ECU
Old Jul 15, 2007 | 05:46 PM
turbo93da's Avatar
Default Re: B20Z2 OBD2 in a OBD1 94 TEG; need wiring help (DC2R_JOE)
do you know the flow of that manifold and tb that would be retarted just my two cents
ls &gt;b20 manifold
Old Jul 15, 2007 | 08:47 PM
Jabinya's Avatar
I would agree with you on the giraffe IM. Strangely mine came with a IM that looks almost identical to the LS IM with the exception of a unknown humongous sensor on top.
I'm still going to switch to the LS IM though.
How do I identify exactly what year this engine was made in?
Old Jul 15, 2007 | 09:04 PM
EARLdaSQUIRREL's Avatar
official honda whore
use whatever harness that matches up with your dizzy/alternator/injectors, everything else will plug right in and not be a problem, btw use that intake manifold as it will fit fine and you wont have any problems, that sensor on the top is part of emissions for obd2 and wont be needed
brian
Old Jul 16, 2007 | 04:33 PM
turbo93da's Avatar
that manifold isnt as bad as the other style
do a google search
appelsos
11
Jul 11, 2011 06:24 PM
novaslean
Apr 14, 2010 09:23 AM
jdm_vizionz
Mar 2, 2009 09:30 AM
red civic standard
Dec 12, 2007 02:52 PM
NOman0608
Jul 26, 2007 10:28 AM
