header bolts
Old Jul 12, 2007 | 09:49 PM
killer_ssn's Avatar
Default header bolts
hey guys just took off my header on my b16a2 and notice that on of the threads on the block are striped can i just re tap and use a little bigger bolt or will it crack the block? and when reinstalling can i reuse the gasket for the header?
Old Jul 12, 2007 | 09:58 PM
MatterMatt's Avatar
Default Re: header bolts (killer_ssn)
Run a tap down the threads and see if the bolt will thread in before trying to "fix" it. The gasket is metal, and although Honda would recommend replacement you can reuse it. I've reused mine twice and haven't had any problems.
Old Jul 13, 2007 | 01:18 AM
killer_ssn's Avatar
Default Re: header bolts (MatterMatt)
just tryed and there are no threads left just a shinny hole should i drill then tap or just tap??
Old Jul 13, 2007 | 01:52 AM
smileycvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killer_ssn &raquo;</TD></TR><TR><TD CLASS="quote">hey guys just took off my header on my b16a2 and notice that on of the threads on the block are striped can i just re tap and use a little bigger bolt or will it crack the block? and when reinstalling can i reuse the gasket for the header?</TD></TR></TABLE>
Well I can promise you that you will not crack the block by using a bigger bolt for your header.
Jose-aka-Pedro
Jul 20, 2006 07:33 PM
Paluce
May 26, 2005 02:25 PM
ebelp
Jul 29, 2003 10:21 AM
geminis2k
Mar 3, 2003 02:45 PM
