FS: AEM EMS 30-1000 CIVIC/INTEGRA OBD 1
For sale AEM EMS stand alone engine managment. 30-1000 model will work on all Civics and Integras that are OBD 1 and any OBD 2 or OBD 0 car with a conversion harness. EMS is complete with all cables and extra harness clip with pins, instructions and most recent version of AEM pro 3.23r9 software and lastest firmware version 1.19 installed from AEM. ECU is in perfect working condition was just recieved back from AEM earlier this month to have firmware updated and everything checked out under warrenty and revision A and mods A were performed all paperwork of this warrenty inspection is included. Also avaliable is a serial to USB cable for an additional 15 dollars if bought with EMS. PM me if you have any other questions.
ASKING $650 OBO
Modified by KillerBee18 at 6:40 PM 7/25/2007
ASKING $650 OBO
I would like to ask a couple questions before i buy.. I know that the newer units have the uago gauge and the ecu and go after your target air fuel ratio using that. They also use a 3bar map sensor and intake temp sensor. Do you have the option to use those sensors with this unit?
Thanks for your time,
Joe Randall
Joe Randall
The EMS is sold to Solorexer... But to answer your questions about the EMS...
All ems units allowed you to wire in a wideband signal either the uego or any other sensors. The newer boxes are offered with uego sensor wired in already, but as far as the map sensor and IAT sensor you can use GM sensors or AEM brand sensors and use wizards to just change the sensor type and it will change any offsets or scalar or any other needed changes for that specific sensor.
