What biggest tires i can put on OE rims, 03 honda accord lx
I got accord 03 lx with origional rims and oe size tires(205/60/15). What is the biggest tires i can put on OE rims that will not require me to recalibrate everything. I am looking for better handling
TIA
TIA
are you talking how wide you can go or how tall you can go, because going taller is going to allow more side wall flex, and end up giving you a sloppy but nicer ride, you wanna go low profile, less flex in the twistys and a little less enjoyable ride
You can go wider, I'm not sure how much wider but the thing you want to stay around is the overall diameter of the tire. You tire is about 24.7" so you want to stay within +/- .5" So whatever tire you are looking at, just calculate the overall diameter and verify it's close and that the width of the tire will fit the rim without rubbing anything on the car while your driving and you'll be fine.
here is a poplur tire sizer site. use it for the diameter touringaccord mentioned.
http://www.miata.net/garage/tirecalc.html
well, first you need to know how wide the stock rim is. The rim size is usually stamped somewhere on the rim.
