pct (b16b ctr) pistons into stock b16a2 block, do i need to modify rods?
Old Jul 12, 2007 | 08:47 PM
n1_egsex's Avatar
* B A N N E D *
Default pct (b16b ctr) pistons into stock b16a2 block, do i need to modify rods?
if i get some pct pistons from the dealer, do i need to do any modifications to my rods? i've heard mixed stories of people shaving off 1mm and stuff like that
and i should have no problems with p2v clearance using OEM headgasket and stock head (no milling)
i'm planning on using blox flat valves, retainers, springs, and blox HSL cams, blox intake manifold and 68mm blox throttle body
i might port the head, depends on how much cash i have left
Old Jul 12, 2007 | 09:28 PM
2ltrtodd's Avatar
* B A N N E D *
'dont put money in blox's pocket they copy and dont R+D'
hahhahhaha i bet someone was gonna say that
Old Jul 12, 2007 | 10:35 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (2ltrtodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ltrtodd &raquo;</TD></TR><TR><TD CLASS="quote">'dont put money in blox's pocket they copy and dont R+D'
hahhahhaha i bet someone was gonna say that</TD></TR></TABLE>
hey im still in college and this is a budget build, whatever gets the job done!
Old Jul 12, 2007 | 10:53 PM
2ltrtodd's Avatar
* B A N N E D *
hahah i hear ya! im in the same boat with college... i know someone was thinkin that though!!
i cant answer the piston-rod question, but p2v you should be ok. if u get gears and wanna change them, id clay or degree the motor tho to check how far both ways you can go!
good luck
later
Old Jul 13, 2007 | 06:19 AM
4g hatch's Avatar
u have to shave each side of the small end of the rod or the inside of the piston
Old Jul 13, 2007 | 08:40 AM
haveaNOSday's Avatar
Default Re: (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">
this is a budget build,!</TD></TR></TABLE>
budget builds = budget engines... don't skimp out you'll regret it later.
Old Jul 13, 2007 | 11:16 AM
n1_egsex's Avatar
* B A N N E D *
Default Re: (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">u have to shave each side of the small end of the rod or the inside of the piston</TD></TR></TABLE>
would you happen to know by how much?
Old Jul 13, 2007 | 05:33 PM
zCivic's Avatar
approx 1mm each side
Old Jul 13, 2007 | 07:16 PM
2ltrtodd's Avatar
* B A N N E D *
Default Re: (haveaNOSday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaNOSday &raquo;</TD></TR><TR><TD CLASS="quote">
budget builds = budget engines....</TD></TR></TABLE>
thanks bill nye. doubt anyone would put those 2 together....
Old Jul 14, 2007 | 03:49 AM
you again you ****** loser!
you just ruined this dudes thread. the only thing you do around here is repeat what you've read from this message board cause you don't know **** you ignorant expletive!!!!!
just to prove how much of an Idiot you are...read this dude SIG. everyone.
a kitty dies everytime a girl masterbates.....thats physics
WTF DOES THAT MEAN YOU RETARD!!!!!
now read my sig.
eka11day
33
Mar 25, 2011 04:51 AM
zachattack54
Feb 25, 2008 02:03 PM
B16EKruger
22
May 2, 2005 10:20 PM
blackspoonem
Jan 12, 2004 09:18 PM
95gsr
May 17, 2003 07:52 AM
