15 inch wheels rubbing on '99 EX sedan?
I put a set of aftermarket 4X100 and 4X108mm bolt pattern 15X6 inch wheels with 195/55R15 tires on opur '99 EX sedan. I got te coorrect size ceneter bore spacers Tire Rack sold me for the car. After I mounted them when I went over any bump I hear a werd noise. I took it to a Honda shop and they say that the wheels are rubbing a BIT only when the rear suspension is not compressed and full extended???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">sounds like you have freaking wide-*** tires!</TD></TR></TABLE>
not the tires, he's running 195/55/15
what is your offset, thats more than likely the problem
are you on stock suspension?
superslow-oto
19
Jul 4, 2006 09:44 AM
