need some motor help
Old Jul 12, 2007 | 12:23 PM
redtegsr's Avatar
Default need some motor help
alright i have a 1994 civic ex with a b18c1 swap in it the head is jdm and the bottom end is usdm for some reason i hit rev limiter at 7200, ive changed out the spool valve screen and i also have changed ecu i have a p28 now and the spark plug wires are in the correct spots, the only code i am runnin is the knock sensor please ineed some help!!!
Old Jul 13, 2007 | 09:16 AM
redtegsr's Avatar
Default Re: need some motor help (redtegsr)
bump
Old Jul 13, 2007 | 10:34 AM
nokturnal_munkeeboy's Avatar
it your ecu , your runnin a p28 ecu and it not chipped or not runing hondata, that why rev limiter is at 7200rpm.
Old Jul 13, 2007 | 11:24 AM
redtegsr's Avatar
Default Re: need some motor help (nokturnal_munkeeboy)
yeah the ecu is chipped
Old Jul 13, 2007 | 01:16 PM
GSR-TRBO-DA's Avatar
by who? stock p28 is for obd1 vtec sohc that is stock redline open up the ecu, see what chip it has. it should have stickers of some sort and say p28 in the bar code on the side. do you have a cel?
Old Jul 14, 2007 | 11:35 AM
redtegsr's Avatar
Default Re: need some motor help (GSR-TRBO-DA)
alright ill open it up and see, yeah im throwing a knock sensor code
Old Jul 14, 2007 | 12:40 PM
wut program are you runnin on that ecu
Old Jul 14, 2007 | 02:44 PM
redtegsr's Avatar
never mind i thought it was chipped but i dont see anywhere where it was chipped at
Sycokid666
Feb 14, 2017 05:10 PM
LUDEcidDream
Engine Management and Tuning
Jul 19, 2010 02:01 PM
obuhmyuh
29
Feb 15, 2008 01:00 PM
streetracerof06
10
Dec 29, 2005 06:14 PM
B16EJ
Jun 25, 2003 08:04 AM
