need the ecu harness wiring diagram for my 1990 civic!
Old Jul 12, 2007 | 12:20 PM
ef8sleepr's Avatar
Default need the ecu harness wiring diagram for my 1990 civic!
I need the chart for the ecu harness for my 1990 civic. i'm trying to find where is the o2 sensor wire on the harness...
Old Jul 12, 2007 | 12:26 PM
jlicrx's Avatar
Default Re: need the ecu harness wiring diagram for my 1990 civic! (ef8sleepr)
the O2 sensor is the white wire at ECU pin C16
Old Jul 12, 2007 | 12:31 PM
ef8sleepr's Avatar
Default Re: need the ecu harness wiring diagram for my 1990 civic! (jlicrx)
is pin c16 in the big ecu harness?? and how do i know which one is pin c16?
Old Jul 12, 2007 | 12:42 PM
jlicrx's Avatar
the 'C' connector is the smallest connector - black in color - pin C16 is on the bottom right when looking at the wire side with the locking clip at the top - white wire - only solid white wire (no stripe) in the connector
Old Jul 12, 2007 | 12:46 PM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1508680 tons of info on ECU stuff in here
Old Jul 12, 2007 | 01:29 PM
ef8sleepr's Avatar
Default Re: need the ecu harness wiring diagram for my 1990 civic! (CRX Toad)
thanks alot. but my c16 pin the wire is white with a redish stripe...
Old Jul 12, 2007 | 01:37 PM
HondaPartsHero's Avatar
Technical Hero
some wires colors vary between years
uncledan
Jul 8, 2009 04:57 PM
5thGenFanatic
16
Aug 28, 2005 05:38 PM
Cornwhiskey
Apr 11, 2004 02:47 PM
Ri5e
Apr 5, 2004 07:37 PM
FUP23
Aug 8, 2002 04:54 PM
