XS POWER CAMS PROS N CONS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkintegra »</TD></TR><TR><TD CLASS="quote">When you had these cams,what valve adjustment numbers did you use?The stock b16 ones?</TD></TR></TABLE>
Seriously, this is the last and final post I will reply to before I report you to the Trojan Accidental Birth Termination Agency. I have put up TWICE that the cams are junk. Let me try some adjective, garbage, ****, loose fecal matter, the cam crower dropped on the floor, XS pukage, SS autoshit, and I am out. If you don't get it after that and realize Don was being facetious due to you lack of ability to comprehend what I am trying to tell you, then buy them at your own risk.
When the cams either A break in half or B wear your rocker pads all the way through in 4000 miles, don't come crying.
its either they're using a clappy material for the cam itself(doubtful). or the profile of the cam sucks so bad that it tears up the pads(likely).
theres more to designing a cam than having the tools to cut them.
i see...so is cam technology like pistons where different percentages of various metals are used to acieve a a certain alloy?
if that doesnt make sense...do different cam manufacturers use different metals for their cams or are they mostly of the same composition?
i understand....is there any particular reason that the different style valvetrains require different materials? does one style produce more heat/friction than the other requiring a stronger/longer lasting material?
hondab16peru
May 11, 2007 05:56 PM
tnsxsear1
Sep 14, 2004 02:23 PM
miksew
15
Sep 19, 2003 08:29 AM
. JDM yo!!
