FS: 91 DX hatch w/b16- N.IL
FS: 1991 Honda Civic Dx w/B16 $2800.00 OBO
Need to sell fast.
PM me here or email is civicflow@yahoo.com
I purchased this car a couple months ago barely running. The wiring was a mess but i cleaned it up. I am waiting on a starter for it so right now it doesn't run.
Specs:
-First gen b16 and trans
-Invidia cat back exhaust
-GSR center console/armrest
-obd to Obd1 conversion w/new dizzy from distributor king and chipped p06 ecu with p30(b16) basemap.
-Injen intake, stock exhaust manifold with heatshield.
-No radio or heat/air.
-Si seats front and rear-front drivers seat is a little worn on the bolster
-shaved valve cover with rattle can metallic paint. has all cam gear/timing belt covers
-VW front lip
I have not done a compression check but will do when i get a starter. i was told it had a check done from whom I bought it and he said it was 190 across the board.
The shift rods are da ones cut down but they need to be cut about a 1/2in more. I do have an ef8 shift rod(the one with the bitch pin)not installed so only the stabilizer bar needs to be cut a little more.
The bad:
Paint is faded
Car will start up the first time then will not restart till the next day. I believe the dizzy wiring is messed and was in the process of fixing that until the starter went out completely.
It needs an alignment.
The usual third gear grind.
The good:
No rust. The car came from Georgia
Engine ran well when i drove it and pulled good.
Interior is decently clean and does have the rear cargo cover.
Car will come on some EP3 wheels(not pictured)
Now some pics(click on pics for bigger pics)
Need to sell fast.
Specs:
-VW front lip
The bad:
Paint is faded
The good:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-v*2 »</TD></TR><TR><TD CLASS="quote">damn i wish my integra was sold</TD></TR></TABLE>
pm'd
pm'd
I still have it for sale but trades are welcome. Right now a house is more important to me than my ef(sillently weeping). I have the urge to dump a lot of money into it but need to hold off.
I need to send back my distributor to dizzy king and get a new one. I am looking for a cheap backup but car won't run until i get my dizzy back from dizzy king or find a cheap backup.
Let me know if you want to check out the car sometime or if you have a cheap used obd1 b16/gsr dizzy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 »</TD></TR><TR><TD CLASS="quote">you can get an ls dizzy and cut the leg off that hits the vtec solinoid
thanks for the info.
</TD></TR></TABLE>thanks for the info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akiraboy »</TD></TR><TR><TD CLASS="quote">bump for a good seller</TD></TR></TABLE>
Thanks, someone buy this civic b4 I decide to keep it. Wiring is sorted out. I have a fuel issue now. I am installing a new fuel filter and fuel pressure regulator. I hope it is not the fuel pump. I have a brand new Walbro pump if needed tho.
not sure how much. probally around $1300 obo. Not sure on price yet tho. Comes with everything except starter, shift linkage, mounts(unless you want the crappy ebay mounts), and throttle body I am thinking(not positive yet). You want it or know someone who does?
I just did a compression check on motor and it was 200+ on all cylinders.
haha those mounts... i just bought those cuz i needed some asap and they were like 75bucks on ebay. and the one that says bad on it was rewelded and its still crooked. but i might have a buddy that might want it. ill have to see. i dont know if he wants to spend that much. did i tell you what i payed for that motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflow »</TD></TR><TR><TD CLASS="quote">decided to keep it. i just picked up a ys1 lsd trans. looking to get a b20z once i sell the b16 and non-lsd trans.</TD></TR></TABLE>
bump for a good seller...what kinda cable trans is on this swap? s1 y1 j1 or?
